Confirm SES reset instructions.
Old Jul 8, 2005 | 06:16 AM
waltj2k's Avatar
I have tried to look this up several different ways.
I have a 2K GXE the SES light has come on. I know it's a sensor but the car seems to be running fine.
Would like to reset the SES light......Think of selling her to CARMAX.
To reset all I have to do is disconnect the battery for one hour or more which resets the ECU, which resets the SES light. Is this correct?
THanks
Walt
Old Jul 8, 2005 | 06:23 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
you can reset it, but if the failure is still present then the ecu will cycle the code back out. the light will come back on after a certain amount of starts/miles driven.
Old Jul 8, 2005 | 06:31 AM
Ammi's Avatar
350 Detroit Muscle
or light might just go away
Old Jul 8, 2005 | 07:06 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
...I guess the bigger question here is, do you know why the light is even coming on? I'm assuming you had the code(s) pulled...
Old Jul 8, 2005 | 07:20 AM
waltj2k's Avatar
Truth be told I am fine with that. I just want to take the car in for an estimate without the SES light displaying.
I do know that it's a sensor as I had the code pulled.
So my understanding of how to reset is correct. Just disconnect the battery for an hour or more....right?
Old Jul 8, 2005 | 07:26 AM
† ErV †
you have to disconnect both battery cables for 25 hours to clear the ecu. but if the problem is there it will light up again. if the problem is fixed or goes away, so will the light on it's own after a while.
Old Jul 8, 2005 | 07:29 AM
waltj2k's Avatar
I see... It not an immediate reset. The ECU has to see that everything is fine 1st before it will turn off the light. Wow 25 hours damn that's a long time.
Hmmm.
Old Jul 8, 2005 | 07:35 AM
sloppymax's Avatar
you only need to remove the negative cable. i used to do mine overnight (8hrs or so) and it was gone in the morning. this was before i got harrison software and run it through my old laptop. i had an o2 sensor issue after headers and used this method many times before the software and it worked everytime.
Old Jul 8, 2005 | 07:41 AM
waltj2k's Avatar
Cool that seems to make more sense. Afterall I have had the SES light come on and have had the car repaired at the dealer in less than 25 hours. When I pick it up there is no SES light.
Old Jul 8, 2005 | 09:20 AM
dennisuello's Avatar
dealer doesn't disconnect the battery to reset the light.
Old Jul 8, 2005 | 09:27 AM
Kevlo911's Avatar
Kevlo for President
I will post a way to check codes(4th gen blink style count) and reset CEL using a PAPER CLIP.
Just wait....
AaronL
Nov 15, 2020 11:52 AM
gigabyte
Jan 6, 2017 06:05 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
220k+ A32
Sep 22, 2015 03:08 PM
