Will 2004 rotors fit with modification?
Old Jul 14, 2005 | 08:49 PM
NJ Devils Fan's Avatar
I need a brake job. I was wondering if 2004 rotors would fit my '02 without any modification needed. I know they are a bit bigger, thats why I want them over stock '02 ones.
Old Jul 14, 2005 | 09:09 PM
irish44j's Avatar
retired moderator
you have 2 options for the 2004/5 rotors:
1. The rotors fit fine, but you will need to relocate the calipers farther out because of the increased rotor diameter. There are brackets available for this. These brackets are available from BlehmCo (www.mattblehm.com)
or...
2. you can upgrade the rotors with the 2004/5 calipers as well. With both of these components, NO modifications are necessary at all - it is straight bolt-up.
I have done both
with OEM calipers, 6th gen rotors, and relocation brackets:
with 6th gen rotors AND calipers
by the way, this only applies to the FRONT, not the back rotors.
Old Jul 14, 2005 | 10:42 PM
FASSTER's Avatar
But will they fit behind the factory 17s on the 02-03?
Old Jul 14, 2005 | 11:34 PM
joebangaa's Avatar
no they will not
Old Jul 15, 2005 | 03:47 AM
MixSE's Avatar
Whiskey Tango Foxtrot
Originally Posted by ighettoboyi
no they will not
Yes they will. In the last brake question thread, someone has done this and he had his stockers on there. I have also done this mod (upgraded rotors and calipers), however, I have yet to try the stock 17s as I am running my summer 19s right now.
Old Jul 15, 2005 | 04:23 AM
maxgangsta02's Avatar
with the caliper relocation kit they well, with the factory 04+ caliper they will not.
irish, great info, where did you source those 04+ calipers? car-part.com or something?
Old Jul 15, 2005 | 08:58 AM
2kVQboodah's Avatar
are the 6th gen calipers any bigger then the 5th gen? i cant tell much a difference. also where can you buy the 6th gen calipers?
Old Jul 15, 2005 | 10:26 AM
joebangaa's Avatar
is it with jeff's relocation kit youre talking about?
Old Jul 15, 2005 | 11:08 AM
LA02MAX's Avatar
with the relocation kit, it will only fit under the 5th gen 17's (not the 5.5 gen) but if you opt to get the 6th gen rotors/calipers/hardware, it will fit using the 5.5 gen 17's...it's been done by dizmax96...look here at post #33: http://forums.maxima.org/showthread....6th+gen+rotors
Old Jul 15, 2005 | 12:16 PM
ICULookN's Avatar
What size bolt do i need to remove the 04 caliper? It's a junkyard I plan to go to tomorrow to purchase one and just want to make sure I take the proper tools.
Old Jul 15, 2005 | 01:12 PM
irish44j's Avatar
retired moderator
YES, THEY WILL fit under the 02-03 OEM wheels...
with stock calipers/relocation kit, they will fit under the 00-01 AND 02-03 17's
with 6th gen calipers, they will fit under the 02-03 wheels ONLY.
Calipers were from DaveB, new.
for those who haven't seen it, here is the size comparison..
Old Jul 16, 2005 | 07:45 PM
Ataraxia's Avatar
Is this a better (or simply less expensive) set up than using the BlehmCo BBK that uses the 350z caliper? Thanks for the posts/pics on this...
Old Jul 16, 2005 | 08:55 PM
n3985's Avatar
大陆弟弟
I am confused, what good is a bigger rotor without a bigger caliper to match? Won't the contact area of the brake pistons still be same?
Old Jul 16, 2005 | 09:05 PM
02theMax's Avatar
I was thinking the same thing?!?!
Old Jul 17, 2005 | 06:55 AM
irish44j's Avatar
retired moderator
The original reason for the blehmco kit using the OEM caliper was simply to get a beefier rotor on there, to stop the rotor warping that is so common on the maximas. We didn't know until later that the 6th gen calipers would also fit!
Old Jul 17, 2005 | 08:39 AM
n3985's Avatar
大陆弟弟
Well, wouldn't the bigger rotor actually be worse than the original one in terms of performance? I mean, the engineers paired the original rotor and caliper together in their respective sizes. Now that there is a bigger rotor, and more rolling mass, won't the caliper have to work harder (albeit a tiny bit) to stop the car?
Old Jul 17, 2005 | 09:19 AM
irish44j's Avatar
retired moderator
no...with a larger rotor, the torque arm effect of the rotor is located farther outward, increasing stopping power (in theory). The downside to the bigger/heavier rotor is, of course, the same as the downside to bigger rims - more rotational mass, which hurts accelleration.
I'll be happy to give up a little accelleration for non-warping rotors though...
as to "the engineers" ....Apparently the Nissan engineers forgot about stopping the car, and gave the maxima a brake system that is grossly inadequate for a 3300-lb car.
Apr 16, 2020 05:15 AM
gigabyte
Jan 6, 2017 06:05 PM
hayne
Oct 5, 2015 11:53 AM
Justin Kroll
Oct 1, 2015 07:03 PM
Socalstillen
Sep 26, 2015 12:01 PM
