Drifting with 01
Old Jul 18, 2005 | 11:44 AM
siren001's Avatar
Drifting with 01
Here is a strange question, I was driving up one of our curvy highways in hawaii and i decided to punch it going around a few corners, and it seemed to drift kind of easy,
has anyone ever set up their 01 or other year to drift?
what stuff did you put use to put on your car
Old Jul 18, 2005 | 11:48 AM
Jeff92se's Avatar
I'm needing a caw
Drifting a fwd? Frifting?
Old Jul 18, 2005 | 11:56 AM
lex3015's Avatar
its not so much that you were drifting as you were powersliding, most likely due to simple tire slip. i do the same sometimes running redlights taking turns in intersections. drifting requires RWD and some skill. you were just going fast with some not good tires
Old Jul 18, 2005 | 12:07 PM
Jeff92se's Avatar
I'm needing a caw
WTF???? .........
Old Jul 18, 2005 | 12:13 PM
Progress's Avatar
It's business time.
Originally Posted by Jeff92se
WTF???? .........
HAHA! I know it sound like they're making the public streets their own autocross.
Old Jul 18, 2005 | 01:06 PM
MrGone's Avatar
that's called understeer, not drifting
Old Jul 18, 2005 | 01:33 PM
E55AMG2's Avatar
Wat
Originally Posted by MrGone
that's called oversteer, not drifting
Fixed!!!!!!!oneoneone
Old Jul 18, 2005 | 01:35 PM
Cutler's Avatar
Do you get it going 90 and then yank the ebrake?
Old Jul 18, 2005 | 01:39 PM
MrGone's Avatar
maximas can't oversteer
they can only snow plow into things
Old Jul 18, 2005 | 01:40 PM
E55AMG2's Avatar
Wat
3rd gen maximas can't oversteer
Fixed AGAIN!!!!!!One
Old Jul 18, 2005 | 01:45 PM
MrGone's Avatar
Old Jul 18, 2005 | 03:12 PM
zoner's Avatar
Sorry man, you can't drift a FWD. I can get a nice four wheel slide out of my Max (rear breaks loose when the front does) with the following - FSTB, RSB (set as low as it'll go), Tokicos - set 2 front, 3 rear. I also run a funny tire size - Yokohama 215/50/R17 (yeah, it's a little skinnier than stock). It's alot of fun, but you gotta watch it - a four wheel slide can put you in a ditch in a hurry.
Old Jul 18, 2005 | 03:14 PM
Lumbee1's Avatar
You guys don't know what you are talking about. I can drift all the front wheel drive cars in Need for Speed Underground.
Old Jul 18, 2005 | 03:29 PM
NmexMAX's Avatar
dot dot dot ...
Things seem to be a bit different in Hawaii ...
Old Jul 18, 2005 | 03:31 PM
ColdSHO's Avatar
my max oversteers, but i have a few more suspension mods then most, and its not like cool bada$$ slide but the rear being just heavy and stiff
Old Jul 18, 2005 | 03:45 PM
nismo0604's Avatar
this thread sucks
Old Jul 18, 2005 | 03:51 PM
NmexMAX's Avatar
dot dot dot ...
Old Jul 18, 2005 | 04:04 PM
sublimer's Avatar
haha i hope thats a joke....
Old Jul 18, 2005 | 04:10 PM
Galo's Avatar
Maxima Pilot
maximas can't oversteer they can only snow plow into things
Actually, not quite true...if you know what u are doing and have the right setup, you can indeed induce a Max into a controlled oversteer condition.
I run a RSB and run the rear tires about three lbs softer than the fronts and I have several times induced a nice, easy, highly controllable (with brake pedal modulation) rear wheel slide or oversteer when turning into a corner while using some rather sizable 'trailing brake'. Obviously the 'slide' corrects when u apply power and unload the front end and inversely load the **** end, but bottom line, yes, you can oversteer a Maxima.
Old Jul 18, 2005 | 06:11 PM
NmexMAX's Avatar
dot dot dot ...
Oh no, Galos on the wine again ...
Old Jul 18, 2005 | 07:04 PM
rmh3093's Avatar
Only gentoo powered Maxima!
Old Jul 18, 2005 | 07:17 PM
joebangaa's Avatar
do you guys have any idea how silly our cars look taking a turn that hard? they look bad enough stock hauling @ss with the rear all sagging
Old Jul 18, 2005 | 07:21 PM
nismology's Avatar
Maybe yours looks silly with that sub in the trunk...
Ben's Avatar
Ben
You do not need a RWD car to obtain oversteer (drifting.)
The maxima is a terrible example, but I have gotten it to oversteer autocrossing.
Here's the setup:
VERY high rear tire pressure to reduce traction and ensure zero tire roll over.
Moderate pressure in the front tires to ensure traction.
Enter the corner too fast for the normal maxima rotation.
Just before understeer has a chance to ruin your run, let of the throttle and tap the brake to tranfer all the weight to the front wheels. The front will bite and turn in. With the reduced weight and reduced traction, the back will break loose and swing arond.
When you apply the gas again, the back catchs and you go.
Of coarse, this took a few times to get right. The maxima wants to understeer like a pig. That' why I don't autocross it anymore.
That's how you create oversteer in a heavy a$$ FWD car like the maxima.
Old Jul 18, 2005 | 07:32 PM
rmh3093's Avatar
Here's the setup:
i dont think that is drifting either since you are being pulled around the turn. drifting needs RWD period... drifing is a controlled slide with more of the momentum of the car being perpendicular to the car than parallel
Old Jul 18, 2005 | 07:43 PM
Kevlo911's Avatar
Kevlo for President
Wait for snow?
joebangaa's Avatar
uhh....no??? yea i know my box is ridiculously heavy but first of all, i don't have a very good idea at what my own car looks like driving around, so i obviously base it off of other 4th and 5th gens i see driving around. in fact, i think the 4th gen's trunk sag is even WORSE than the 5th gens. but seriously, 5.5 gen GLE's look terrible stock when they're accelerating.
Old Jul 18, 2005 | 07:53 PM
E55AMG2's Avatar
Wat
Mine doesnt sag...or roll..or dive, BUT I also run coilovers
Old Jul 18, 2005 | 07:55 PM
Woody's Avatar
FF's can drift also. They do it in japan.
Old Jul 18, 2005 | 08:02 PM
Ben's Avatar
Ben
It's certainly not the same as the "sport" of drifting. However, it is a serious oversteer situation in which you have to counter steer to keep the front end living up to it's name. The result is a sideways slide of the back wheels. I call that drifting through a turn. Everyone else in G-stock called it a miracle.
Not nearly as much fun as taking an s2000 through a mountain road sideways, but still drifting.
litch
123
Jan 4, 2024 07:01 PM
SptBiz
Apr 5, 2002 12:10 PM
Takumi
Dec 3, 2001 09:32 PM
Chebosto
Nov 3, 2000 08:23 PM
