Improving A/C performance
Old Jul 22, 2005 | 10:31 AM
Weimar Ben's Avatar
Helicopters! Money!!!
I was adding some R134a the other day and came up with an idea-wrap the A/C lines with insulating reflective silver tape. The low pressure line connects to the compressor right next to the exhaust and near the radiator. If you wrap the lines with insulating tape, you should keep the lines cooler.
This should be good for cooling down the air a few degrees, especially in stop and go traffic when the cooling fan comes on all the time.
Old Jul 22, 2005 | 10:43 AM
TXT-1's Avatar
How do you know your R134a is low? My AC doesn't feel as cold as it should be.
Old Jul 22, 2005 | 10:47 AM
jjs's Avatar
jjs
You can get one of those 'self recharge' kits that has the little gauge attached to the hosing.
Old Jul 22, 2005 | 11:48 AM
K Pazzo 6's Avatar
yep did this for 1st time 3 weeks ago...can cost like $25 from Murray's...
Old Jul 22, 2005 | 11:57 AM
TXT-1's Avatar
Is this easy to do? Not too mechanically inclined here...
Old Jul 22, 2005 | 12:12 PM
jjs's Avatar
jjs
Actually, very easy...I have had to do it a couple times to my Ram which I don't feel like spending $$$ on repairing.
Old Jul 22, 2005 | 12:18 PM
n3985's Avatar
大陆弟弟
I remember on g35driver.com the people there wrapped their metal AC lines with this rubber foam kind of tubing, to which they say the AC is now colder.
Old Jul 22, 2005 | 12:31 PM
itdood's Avatar
I don't think it would help. If it did, don't ya think the manufacturer would have done that?
A properly functioning AC system will cycle the compressor on and off ayways. There's a sensor built into the evap side to shut the compressor off to prevent freezing the line. Hard to tell in the Max, but the compressor does cycle, at least on mine it does. That's how I know the system is working at it's best, because if it weren't, the compressor would never shut off, or it cycles too fast and doesn't get cold.
Old Jul 22, 2005 | 12:36 PM
Weimar Ben's Avatar
Blowing hot air over lines that have A/C coolant in them can't be good for efficiency. Especially lines that are made of aluminium which does a very good job at transferring heat.
Old Jul 22, 2005 | 01:25 PM
itdood's Avatar
I'm sure the engineers that design these know that. There must be a good reason why not a single car ever made came from the factory with those line insulated.
Old Jul 22, 2005 | 01:28 PM
TXT-1's Avatar
You know this for a fact??
Old Jul 22, 2005 | 01:38 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if the engineers were that flawless in their planning then no rotors should warp prematurely. this is just one of numerous examples but also consider they must work within a budget. if they can get the air cool as on previous models then the job is done. if someone can/has figured out a way to lower the air temp a few degrees then more power to them. the same principle holds true on ac lines to a house. there is a reason for insulating them. for 5 bucks of 30ft wrapping from lowes then its worth it for me to try.
Old Jul 22, 2005 | 01:46 PM
Weimar Ben's Avatar
Engineers don't get to implement everything they want either because of costs or other considerations. I'm sure that nissan engineers know that headers would improve performance but don't use them because of cost. If engineers weren't constrained by cost, you would get something as expensive as a Porshe or a Ferrari.
In warm weather, this probably wouldn't make much of a difference. But here in the west right now, there's a big heatwave. It's been about 105-110 lately where I live and the A/C isn't quite up to the task. If this could lower my temps by a few degrees for $5, than it's worth it.
Old Jul 22, 2005 | 01:50 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Speaking on behalf of engineers, no, you cannot put every little $0.02 worth of improvements into a car. The a/c was likley deemed as being 'cold enough' for the cost at time of production, hence why they did not provide additional mechanical improvments to the system, thereby reducing total cost.
Old Jul 22, 2005 | 03:15 PM
Weimar Ben's Avatar
http://g35driver.com/forums/showthre...ighlight=a%2Fc
Old Jul 22, 2005 | 03:27 PM
n3985's Avatar
大陆弟弟
..thanks for finding it.
Old Jul 22, 2005 | 03:31 PM
Can someone give me he Cliffs' Notes? I am not going to join to read a single thread
Old Jul 22, 2005 | 03:38 PM
Weimar Ben's Avatar
It basically says the same things that are said in this thread. A few people there tried it and it did cool down the air a bit.
Old Jul 22, 2005 | 03:50 PM
E55AMG2's Avatar
Wat
Older Mercedes and BMWs wrap their refrigerant lines (which incidentally were intertwined with the fuel lines on older models). Someone try, and report the #s from the a/c test mode.
Old Jul 22, 2005 | 04:25 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Our cars use a variable displacement compressor, so the clutch is always engaged, ie always on, UNLESS you have low outside temps, low refrigerant, main switch or fan switch is turned off, and I also think under high engine load/WOT. Anyways, if you're hearing your compressor kick on and off, you'd better check your refrigerant.
The compressor is turning low pressure gas into high pressure gas, which adds a lot more heat then ambient temp adds. Even if you could make a significant temperature difference, by definition of PV=nRT, our variable compressor would just compensate by adding more heat by trying hold the same pressure.
At least that's what my half-fried brain says when reading the FSM A/C section.
Old Jul 22, 2005 | 07:06 PM
itdood's Avatar
Trying to properly test that would be tough. Climate control may not be blowing straight through the evap if the car is out of the sun or outside temp sensor is reading something different then your test before you wrapped the lines.
Automotive AC is designed to run colder than residential AC. WHere a residential AC will blow about 55^ at the vents, car AC will be down around 32-36 at the vents if you are blowing straight through the evap. As is, they run close to freezing the evap and lines, I just don't think you guys are going to get much more out of it by insulating. If it's working right to begin with, a car AC can't get much colder. In my other car, I keep a thermometer in the vents, and when it's cooled off, the vent temp is 32-35. To get colder then that you'd end up freezing the evap and the cold side sensor just won't let that happen.
Old Jul 22, 2005 | 07:10 PM
itdood's Avatar
To be honest I've never been able to tell with my Max. My other car does cycle the clutch and I can feel that when I'm driving it. I'm glad the max has the variable displacement thingy because when the clutch engages and disengages on the other type, it's harsh at times.
Old Jul 22, 2005 | 09:01 PM
TXT-1's Avatar
I wish we had a "that went right over my head" smilie....
Old Jul 23, 2005 | 08:06 AM
Weimar Ben's Avatar
The FSM quotes vent temperatures only 30-40 deg below that of the air that passes over the evaporator.
Maybe I have something wrong with my A/C, but with this 105deg weather, my car never cools off enough to be comfortable. I think I would kill for vent temps of 32-35deg, I think I prolly have 70-75 when the outside temp is 105.
Old Jul 23, 2005 | 08:48 AM
Weimar Ben's Avatar
[QUOTE=IceY2K1]
The compressor is turning low pressure gas into high pressure gas, which adds a lot more heat then ambient temp adds. Even if you could make a significant temperature difference, by definition of PV=nRT, our variable compressor would just compensate by adding more heat by trying hold the same pressure.[QUOTE]
The compressor doesn't really add "heat," it compresses the low pressure gas which in turn increases its temperature and pressure. I guess the line going from the condensor to the evaporator is what would need to be insulated.
In thinking about this more, the line that goes from the evaporator back to the compressor should NOT be insulated. In fact, the more heat that is added to it, the better since the compressor wouldn't have to compress the gas as much to attain the same temperature and pressure.
Old Jul 23, 2005 | 07:49 PM
itdood's Avatar
And that's in a car that has 150k miles on it, and is 11 years old. And I've never recharged the thing. Even on days in the mid 90s when the car's been in the sun for 8 hours. On the the worst of days, the temp guage in the vent will read 140^F when I first get in the car. When it's that hot it will take about 15 minutes to get down to 35^ or so but it does. It's not R12, it was one of the first R134a cars, back in 1994-95.
I've never checked the vent temp in my Max but that get's cold too.
Old Jul 25, 2005 | 09:25 AM
CVicVogel's Avatar
GUYS...GALS....BE SURE YOUR CABIN AIR FILTER IS CLEAN!!
A CLOGGED CABIN AIR FILTER WILL RESTRICT COLD AIR...CAUSING YOUR SYSTEM TO WORK HARDER!!
CHANGE THE FILTER...AND THE COLD AIR WILL FLOW IN EASIER!!
On a different note: I had tough problems cooling my Bonneville..like all the time. It was really pitiful even after recharges!
I did wrap the "cold" line into the firewall-it did help. I ALSO applied the foam tape insulation around the firewall where the air conditioner was. I did everything to limit hot air contact with the cool areas.
Do it...you can make a difference!
Old Jul 26, 2005 | 06:14 AM
silversurfersg's Avatar
Nice enthusiasm and animation! ha
Old Jul 26, 2005 | 09:13 AM
VQ30GTR's Avatar
Dude,
Your caps quote made my day-Thanks.
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
Sep 27, 2015 08:37 AM
Socalstillen
Sep 26, 2015 12:01 PM
pears
Sep 18, 2015 05:25 AM
