2002 brake shim kit
Don't know but I sould reuse the factory shims. They are beter quality than any aftermarket shims you will get. Just clean them up real good and slap a little high temp lube on there. I the pads you get come with shims allready applied on them use them but if there loose in the box stick on style then use the oem shims.
Originally Posted by desperado_45
I just ordered some no name shims for 8.00 in case i cant reuse mine. The stealership wanted 48.00 dollars and they dont have them in stock. Which tells me they dont replace them when the do a brake job.
If you have factory shims on your pads now then you will be able to reuse them. The factory shims are not glued or rivited on.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
