home depot grill
Old Jul 30, 2005 | 10:17 PM
cobalt416's Avatar
home depot grill
irish... i noticed yout HD grill on your website. have you noticed any increase in the engine temp(less ventilation, i suspect) because of the mod ? i have been thinking about doing the same thing to protect the cooler, since i got a few too many dents on by small rocks or gravels.
did u pre-cut it using a paper board or something like that ? still have the measurements ?
thx
Old Jul 31, 2005 | 06:39 AM
irish44j's Avatar
retired moderator
when I cut it, I made a cardboard template, and then cut the mesh.....sorry, don't still have the cardboard. Also, no to my knowledge it has had no effect on ventilation.....
Old Jul 31, 2005 | 09:43 AM
ticko's Avatar
i want to do the homedepot grill as well, do you have to take out the gril to do so or do you just put it on in front of it?
is there a howto on here to do it?...
Old Jul 31, 2005 | 10:35 AM
irish44j's Avatar
retired moderator
All you need to do is go to Home depot, buy a pack of steel gutter guards, cut them to shape, and secure then BEHIND the factory upper grill (you can also do the lower grill). There are a few pics on my homepage, but they're not all that good....it just takes some patience and ingenuity, but there are several ways to do it....
Old Jul 31, 2005 | 10:39 AM
ticko's Avatar
oh ok i c, so you put it behind the grill, what color did you paint yours, i want miine to be as chrome as it could be...
and for the bottom part of the grill, do you have to go under the car behind the bumper?...
by the way, can you just by the yellow bulb to make ur fogs look like that?...
Old Jul 31, 2005 | 11:26 AM
cobalt416's Avatar
thx for the info irish. how long have you had the grill on ? notice any rusting ? i know they are galvanized steel, and should be slightly protected from rusting...
ticko, i looked at the space in between and should be able to just slide the grill in, might need someone's help to hold it in place while you secure it thou.
Old Jul 31, 2005 | 12:16 PM
irish44j's Avatar
retired moderator
1. I painted it black, since my grill is painted black and I have a black car. FYI, chrome paint is NOT very "tough" and will chip easily.
2. For the bottom part, it is attached in FRONT of the vertical supports, cut to fit the shape of the opening.
3. NO....yellow bulbs will not be as yellow as mine. I've used them, and they're not that yellow. Mine has a yellow capsule and uses my STOCK bulbs...do a search, there are several how-to's on the subject.
Old Jul 31, 2005 | 12:18 PM
irish44j's Avatar
retired moderator
1. No rust problems, and I put them on last year BEFORE the winter...last summer as I recall. Only tough part with galvanized is that you have to prime it really good with a certaian primer that sticks to galvanized. Regular paint doen'st stick as well.
2. Yes, if you cut it right, it will stay in there fine while you secure it. I used zip ties hidden where you can't see them easily.
Old Jul 31, 2005 | 12:25 PM
GBAUER's Avatar
Are you talking about the rubber bulb covers they sell in the ricer section at pep boys? I just bought a set of red ones because I needed a way to cover the opening that was left when I removed my breather hose from my Injen. I installed a filter on the valve cover opening to help keep oil out of my intake manifold.
Just a dumb question: do you think we might actually be doing some harm by getting all the oil out of the intake system? Is is remotely possible that we need some to blow in there to lubricate moving parts? Just a thought.
Old Jul 31, 2005 | 12:27 PM
irish44j's Avatar
retired moderator
You sure you're in the right thread George?
and no, we definitely don't need that crap in the intake system...
Old Jul 31, 2005 | 12:47 PM
GBAUER's Avatar
Ya, just got a little side-tracked. Post-whoring ADD style!
Old Jul 31, 2005 | 07:30 PM
roll4life's Avatar
i just bought grille mesh and im going to try to install it on top of the stock grill not behind..anyone got any tips other than make a cardboard template? or how i should attach it?
sorry for goin a little off topic guys
Old Jul 31, 2005 | 08:48 PM
ticko's Avatar
i bought the grill today from home depot for 1.75 cent i think it was, now what tool do i use to cut the grill, and where did you use the zip ties on the bottom grill?...
Old Aug 1, 2005 | 10:30 AM
ticko's Avatar
Old Aug 1, 2005 | 11:09 AM
speye022's Avatar
your site is under construction...i just wanted to see the lower grill done. If you have pics of it, could post some?
Old Aug 1, 2005 | 05:56 PM
irish44j's Avatar
retired moderator
my site is working fine
anyways I went out and took some flash pics so you can see some detail....in the day it's black, it just looks gray because of the flash. Also it's very dirty since it just rained here...
anyhow, look closely and see if you can find where the zip ties are
Old Aug 1, 2005 | 08:51 PM
ticko's Avatar
yah what about the sides of the grill on the lower part? did you tie them down?...
Old Aug 2, 2005 | 02:13 PM
irish44j's Avatar
retired moderator
they are cut to hold themselves in there with a few zip ties.....
Old Aug 2, 2005 | 02:35 PM
ticko's Avatar
oh, what tool did you use to cut your grill, im having trouble...
Old Aug 2, 2005 | 03:54 PM
Morgan06's Avatar
Isn't that a girl's name?
tin snips. shears. wire cutters. dykes. bolt cutters. if you cant find one of those just ask your mom, i am sure she can finish the grill for you.
Old Aug 2, 2005 | 07:01 PM
spring02's Avatar
I also have a short write-up on my cardomain page that is slightly different from Irish's if you want Cobalt (pg. 11). It has the exact measurements of my lower grill if you need them.
Old Aug 2, 2005 | 07:39 PM
irish44j's Avatar
retired moderator
Nice writeup, spring02......that should answer all the questions since I was too lazy to do a writeup on it
Old Aug 2, 2005 | 08:29 PM
cobalt416's Avatar
thx spring02 and irish, good job ! spring02: i have a 2001 gxe black and metall tint as well. just got the 3m clear bra in the mail, going to put that on one of these days. not sure if i want to paint the grill (sounds like much work to me), nor do i want it silver color. i might actually just spray it with rubberized black paint(much salt here, in Toronto). i might have to leave a small hole in it so the engine block heater plug in could get thru. will post some pic after i am done with it.
REDinLV
Aug 15, 2024 12:30 AM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
