Need confirmation of timing advance in Canadian 02max
Old Aug 2, 2005 | 05:49 PM
Mr_Red's Avatar
I just got my car back from the dealer after an MAF ecu flash (which is free for any canadian Maxima under 8 yrs and 100,000km) after upgrading your MAF.
Also note for all canadians, the 2k1 MAF is $600 in canada, the same as the upgraded AM600 2k2 sensor, but the 2k1 MAF is available delivered to canada for about $120 canadian from the US. I did it and it works fine.
While at the dealership I asked to have my timing advanced to 17 (+2) degrees.
The offical word was that this was not possible from the tech, after having my car go to the shop. The service desk made no complaints when I booked the car.
The tech said he could only advance the timing for testing purposes, but not where he could make the change stick. He started to get really pissed when I asked if I should dl the instructions off the internet for him. He said all the US guys must have aftermarket ECU's
Can someone please confirm that you can advance timing on a canadian 2k2 or 2k3?
Old Aug 2, 2005 | 06:21 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
the ecu is not different. i am sure there are package differences but the ecu is not going to be any different. the main objection from techs that do not know what they are doing is that the timing will not stick. it will stick, even after disconnecting the battery or even the 2k2/k3 ecu reset. it will on revert back to stock timing when the consult 2 is rehooked up and the timing is then set back to 14-15 btdc. i understand the techs frustration though. dont you hate it when you dont know what you what you are talking about and someone else does?
Old Aug 2, 2005 | 07:16 PM
BewstAdd1ct's Avatar
timing advance isnt available on 02-03, AFAIK...
Old Aug 2, 2005 | 07:31 PM
IWNTMORHP!!'s Avatar
CAN YOU PUT IT ON THE WALL?
yes it is...i have a canadian max and the tech has set it and i have had it checked several times to ensure it is still advanced...the tech is not very knowlegable. the consult 2 will not allow any more than 17total degrees...usually only plus two if you're at 15 degrees advance. mine was at 14 degrees, so they were able to take it up 3 degrees...to 17.
by the way, thanks for the info on the warranty. I was not aware of that. i wonder if i have to take it to a canadian nissan dealer for that. the local dealer will not cover anything after the 3/60 US warranty. could use my evap canister and controll valve replace under warranty
Old Aug 2, 2005 | 08:21 PM
Mr_Red's Avatar
I believe you with this one, but my dealership service department's standard response when I come to them with what seems to be very solid info from this fourm, I get 'All that stuff on the internet is made up'. (The next nearest nissan dealer to me is 200mi from me, the next is 500. They squirm like babies when I give them copies of the TSB, but they will still deny it.)
How the hell do I tell what he left it at. Right now it feels like it may have been retarded, if anything. Can a OBDII scan tool do it? Right now all I own is a code reader, not a scanner (I think that sort of thing exists)
Old Aug 2, 2005 | 08:30 PM
Jaws's Avatar
There is no difference between a Canadian spec Max and a US spec Max other than the speedo, odo, ACC, ambient temp display and trip computer reading in metric. There is no way to advance the timing yourself or check to see what it is currently set at. It must be done with the Consult II tool that your dealer has.
I forgot the DRLs. One thing, don't be surprised if they try to charge you an hour for upgrade, even though it will take 10 min.
Old Aug 2, 2005 | 08:32 PM
Jaws's Avatar
You are wrong.
Old Aug 2, 2005 | 09:50 PM
Mr_Red's Avatar
The MAF ECU reprogram warranty was not related to a canadian Maxima warranty. My car currently has no warranty. I think this is an item specific warranty, probably thanks to some specific defect. When contacting a dealer in edmonton where my MAF failed (4-500mi from home) they anted to sell me the old defective MAF for my car and would not sell the updated sensor. Make sure if you do a MAF change use a AM600 2k2+ or 2Y001 2k0 & 2K1 I used a 2y001 and transfered my thermistor from my old sensor. The MAF was from the US and its box included a bulliten saying that the car needed to be reprogramed There was one notice for the US and one notice for Canada.
Old Aug 3, 2005 | 08:33 AM
Originally Posted by Jaws
You are wrong.
thats why i said 'AFAIK'... but dont tell me, hun... show me
Old Aug 3, 2005 | 08:40 AM
Puppetmaster's Avatar
Look for the threads, they are out there... like this one:
http://forums.maxima.org/showthread....timing+advance
Old Aug 3, 2005 | 08:47 AM
http://forums.maxima.org/showthread....58#post3718358
the procedure must be COMPLETELY different from an 00-01, eh?
im looking for the NYPD thread for 'dealing with clueless dealers'... google turns up nothing
Old Aug 3, 2005 | 12:40 PM
sloppymax's Avatar
a good quality scanner should have the ability to read timing functions. i run harrison obd2 software on my laptop so i can guarantee the timing sticks. you should be see where the base timing if you have a good scanner/tool. the procedure for the 3.0 & 3.5 is the same. the consult 2 is the tool used to advance the timing and you take the same steps on both engines.
Old Aug 3, 2005 | 12:54 PM
i wonder if a tech2 can adjust the timing...
Old Aug 3, 2005 | 01:40 PM
NewLoveI30's Avatar
Id like to see the same thing. I'm going to the dealer this friday and would love to have them do this while it's in.
Old Aug 3, 2005 | 02:03 PM
scopium
if u want timing advance.. go straight to a tech thats on a brake . slip him 40 bucks or so and he will do it.
Old Aug 3, 2005 | 03:04 PM
Glude's Avatar
I recently got mine done for free from a tech locally, I was suprised to say the least. First time that dealer was nice to me.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Starrider
Sep 17, 2015 07:26 AM
homeyclaus
Sep 3, 2015 06:15 PM
305head
Aug 26, 2015 09:03 PM
