squeeky windows
Old Aug 9, 2005 | 01:26 PM
MxdOut97's Avatar
squeeky windows
anybody else have squeeky windows when you put them up or down....any solutions????? thanks
Old Aug 9, 2005 | 01:41 PM
Kevlo911's Avatar
Kevlo for President
The guide window uses to go on, spray WD40 or Silicone Lubricant on it and clean it out with a Q-Tip or corner of a rag.
Old Aug 9, 2005 | 01:53 PM
SoonerFan's Avatar
Cletus
not WD-40. its oil based and will attract more dirt
How to fix problem of windows rolling up slow and squeaking.
RED - Run a wet rag in the window track then spray whole thing with silicon spray.
BLUE - Wipe inside both rubber pieces with wet rag.
Old Aug 9, 2005 | 02:02 PM
MIXXMAX's Avatar
Yeah, Sooner is right. WOW, it's odd because I had done this today because my driver's side window would always come back down 1/4 way because the track was sticky. Also, if you have tint (like me) watch that you don't get overspray on it. Wait 'til the silcone evaporates.
Old Aug 9, 2005 | 02:48 PM
Nomad's Avatar
This is the exact write-up I used for my pssenger shquicky window. Nah I used tire shine seems fine now.
Old Aug 9, 2005 | 04:21 PM
HitmanAngel2k3's Avatar
I used silicone spray and it works like a charm thanks sooner
Old Aug 9, 2005 | 05:04 PM
Ryals's Avatar
SHIFT_this
Where's a good place to get silicon spay? Any specific brand? I'm also having slow squeeky window issues.
edit: found some at my base gas station, Brand GUNK, only $2.75 a can
Old Aug 9, 2005 | 06:42 PM
MIXXMAX's Avatar
Any auto parts store has them. No particular brand is better than the other. It's only a couple of dollars a can.
Old Aug 9, 2005 | 06:55 PM
OOmaxSE's Avatar
i got squeeky windows on all FOURS. is this common on 5th gens???
Old Aug 9, 2005 | 07:01 PM
NJ Devils Fan's Avatar
I have squeaking in my rear driverside all the time and occasaionally in my rear passenger. I just thought it was my custom maxima stickers but now I will try this. Is there anything I can use instead of silicon spray? Trying to save my money.
Old Aug 9, 2005 | 07:20 PM
MIXXMAX's Avatar
Yeah, but silicone is the best way to go. Again, it's only like $3-$4 a can.
Old Aug 10, 2005 | 02:54 PM
BewstAdd1ct's Avatar
its common on all cars. i spray the window with glass cleaner, and run it up and down a couple times, spraying each time. and also use silicone spray on the side tracks.
Old Aug 10, 2005 | 05:47 PM
Twista69's Avatar
I have squeakage on the passenger side window, I'm gonna hit with window cleaner tomorrow and see what happens.
Old Aug 10, 2005 | 09:55 PM
I'm going to have to add "squeakage" into my lexicon.
Old Aug 11, 2005 | 06:23 AM
Maxrider24/7's Avatar
I have the same problem.....thanks guys, I thought it was just my windows....good thing for the org.......
Old Aug 11, 2005 | 04:56 PM
Ryals's Avatar
SHIFT_this
Just a hint: I decided to do my front windows at lunch because my passenger side was terrible. Anyway after completing the instructions posted by sooner, my front passenger was still a tid bit slow coming up, as if it was still catching so I cleaned and spray the lil short 3-4 inch groove by the mirror and presto!! Up and down faster with ease.
Quick question? The windows to move quicker and easier, but my passenger is still about a sec slower going up than the drivers side. Anyone else witness this in there car or will I be looking foward to replacing the window mech soon?
Old Aug 11, 2005 | 05:07 PM
I just bought the spray and holy $hIt it worked great.....thanks again guys
Old Aug 11, 2005 | 05:12 PM
Lytheum's Avatar
nah....my driver side goes up faster too. i assume its normal?
Old Aug 11, 2005 | 05:13 PM
SoonerFan's Avatar
Cletus
glad its working for everyone. the problem is bad if you roll your windows up and down alot. dirt gets in the grooves.
Old Aug 11, 2005 | 05:20 PM
Ryals's Avatar
SHIFT_this
Yeah I constantly roll my windows up and down. Its extremely dusty here too. The silcone spray I used was made by GUNK and it was only $2.75, I like cheap fixes.
Old Aug 11, 2005 | 08:29 PM
My driverside goes quicker than the passenger. Sometimes, the driverside comes back down a bit which is a pita. Its very very rare.
Old Aug 12, 2005 | 12:05 AM
mclarengts1's Avatar
thanks I gotta do mine too
Old Aug 12, 2005 | 01:56 AM
NisMo-Max's Avatar
ill be doing this tomorrow also, thanks soonerfan...
Old Aug 12, 2005 | 03:19 PM
gsumax's Avatar
I thought the window roll down thing was because of the regulator needing to be reset? did spraying the tracks resolve that problem? because i have the same issue and its a pain, my car got wet the other night because the valet didnt notice that the window rolled down a bit and left it parked like that
Old Aug 12, 2005 | 03:27 PM
Ryals's Avatar
SHIFT_this
I know my front passenger side was terribly slow coming up, but its 10x better now. The passenger side windows still come up about a sec or two slower than the drivers side though. I just figured with all four windows coming up together that the drivers side took priority on power.
Old Aug 12, 2005 | 04:26 PM
MIXXMAX's Avatar
Yeah, what was happening in my car is that the tracks were so dry, when the window was going up in auto mode, the window was dragging and slightly jerking off track. This, in turn, made the window stop and come down a 1/4-1/2 from the top. The auto up mode is designed in our cars in way where if it feels any resistance while going up, the window will automatically stop (a safety feature so that you don't get your fingers, hand, or anything else get caught in the window.) Yeah, and after I sprayed the silicone, it then glided much more smoothly.
Old Aug 12, 2005 | 05:25 PM
gsumax's Avatar
cool, good to know, ill give it a shot. Thanks
Old Aug 12, 2005 | 07:22 PM
anyone having a slow window after lubing tracks and rain channels might consider pulling the door panel and greasing the regulator with AN APPROVED WINDOW REGULATOR GREASE.
Old Aug 12, 2005 | 09:01 PM
Finally did mine today and it worked great, no more squeakage and all the windows are a bit faster.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
Luev
Sep 30, 2015 11:50 PM
