The Dealer Can Bite Me New TB
Old Aug 9, 2005 | 06:54 PM
traderfjp's Avatar
Just an update. I bought a used TB for my Max. The car only had 10k on it and the numbers matched my TB. I got it really cheap at $125.00. I had cleaned my TB when I first got the car and immediately had a high idle and CEL. Well the code being kicked out is for the IACV which is 300.00 aftermarket or 700.00 from the dealer because it comes with the whole TB as one unit. I'll be getting this part soon and posting the results. If this doesn't fix my situation then I'll change out the ECU. After that I'll have to swallow my pride and take it to the stealership.
Old Aug 9, 2005 | 07:03 PM
dgmaxse's Avatar
Same thing happened to me with my wife's 03 Altima. Cleaned the TB, with carb cleaner, being careful to wipe what I sprayed, but I'm sure some got past the TB. CEL came on. Thankfully it was under warranty still so was replaced. Weird, did this on my 91 sentra a few times while I owned it w/o problems.
Old Aug 9, 2005 | 08:02 PM
jjames's Avatar
i really hate to say this because i'm not sure how it will come across. but, if you are throwing codes and causing enough damage to require $700 worth of parts to your car by cleaning a throttle body, you should probably keep your wrenches away from your car.
Old Aug 9, 2005 | 08:32 PM
traderfjp's Avatar
Well jjames I'm sure guilty of not doing my research on how to clean a TB on an 02 Max. I've always cleaned the TB of all my cars and never had a problem. Turns out the 02 Max uses a wire to control the opening and closing of the TB so following the directions on the intake cleaner's label will cause problems with our cars. I must have messed up the IACV in the TB. My lesson learned is to be more careful in the future.
dgmaxse: What part did the dealer replace to fix your wife's Altima?
Old Aug 9, 2005 | 08:53 PM
jjames's Avatar
i hear ya. that's the problem w/ cars these days. i don't know how old you are but in my first car i could pretty much crawl in the engine bay and work on it. today you need to be sooooo careful, and consult the service manual first.
Old Aug 10, 2005 | 02:58 PM
BewstAdd1ct's Avatar
why is that a problem? because they didnt build them so you could work on them?
did you guys try doing the idle air vol learn process?
Old Aug 10, 2005 | 03:14 PM
jjames's Avatar
yeah...pretty much.
Old Aug 10, 2005 | 04:14 PM
meh... blame the EPA
D Mason
Jun 21, 2016 04:43 AM
mpbclutch33
Dec 26, 2015 11:11 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
AboveDaCloudz
Oct 8, 2015 11:25 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
