Exhaust flow... 2000 Auto GLE
Old Aug 11, 2005 | 04:50 PM
xplosive9z's Avatar
Replaced spark plugs (NGK), put a new MAF in today... and the exhaust is still "puffing"... the gas is not coming out smoothly like it should be, i can feel the puffs if i put my hand by the exhaust...
suggestions?
Old Aug 12, 2005 | 09:17 AM
xplosive9z's Avatar
suggestions to previous?
any suggestions fixes?
Old Aug 12, 2005 | 09:20 AM
gameover03's Avatar
coils maybe or something with the fuel injection possibly malfunctioning or dirty..have u conducted any fuel injector treatments?
Old Aug 12, 2005 | 09:56 AM
xplosive9z's Avatar
no not since i've got my car...
i have about 130k... i bought the car at 112k...
i'm going to have a fuel injection service, oil change, alignment, transmission flush all done in one shot...
you think that'll cure it?
btw, new maf installed yesterday, NGK's installed a week ago...
Old Aug 12, 2005 | 10:02 AM
igzy's Avatar
I Know Kwaliti
Updated the ECU after MAF replacement?
For your injectors you could do the Sea Foam treatment...
Sounds like your idle is not even. Am I correct? You may want to change your PCV, clean the throttle too... Not sure if your IAC is working properly either... This is assuming that you have rough idle...
Old Aug 12, 2005 | 11:33 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if there is a considerable pause in the exhaust coming out then id check to make sure one of the precats or possibly even the main cat is still in tact.
Old Aug 12, 2005 | 06:38 PM
BewstAdd1ct's Avatar
yes, especially if its 'hissing' under cruise or accel.
if you have a vacuum gauge you could find out quite a bit... sounds like misfire, or partial misfire, burned exh valve or exhaust issue.
RinconI30
Jun 11, 2016 08:25 PM
QueensMAX
Sep 15, 2015 04:14 AM
Bernhard
Sep 14, 2015 12:49 PM
ballerchris510
Sep 11, 2015 05:29 PM
Maxboy23
Sep 4, 2015 06:04 PM
