urgent oscai help
Old May 24, 2001 | 11:55 AM
jw82's Avatar
how the !#$!#$ do i route the hose to the splash guard area?????
its so blocked i cant see anything
if u know plz reply soon coz i want to finish asap since i cant drive with everything out
Old May 24, 2001 | 12:10 PM
kpark's Avatar
What kind of hosing are you using? If you're using the aluminum exhaust piping found at hardware stores you can bend it to make its way down to the splash guard.
Old May 24, 2001 | 12:16 PM
punkdork's Avatar
Be sure to remove the L pipe from your resonator.
Old May 24, 2001 | 12:21 PM
jw82's Avatar
i removed the L pipe already... i dont see any place where the tube can go through to get anywhere near the splash guard or even under the car at all
Old May 24, 2001 | 12:23 PM
UMD_MaxSE's Avatar
Got Bent?
how long is the tubing?
Old May 24, 2001 | 12:27 PM
punkdork's Avatar
Take a look at the pics on my site. Mine was able to go straight down. The tubing is 3" in diameter.
Old May 24, 2001 | 02:15 PM
y2kse's Avatar
Agreed. I used 2.5" shop vac hose and it went straight down to the splash guard. With the L-bracket out, there shouldn't be anything in the way. If there is, take a picture and post it here. We'll try to figure out what your problem is.
Old May 24, 2001 | 02:21 PM
jw82's Avatar
i think i got it now.. it just points straight down, if i put a perpindicular tube thingy so that the thers an opening facing foreward will there be any drawbacks?
btw thanks everyone for all the help
Old May 24, 2001 | 05:24 PM
y2kse's Avatar
There are a lot of different opinions on how to orient the open end of the tube. I keep mine inside the splash guard to prevent the OSCAI from sucking up airborne matter. Others mount it under the splash guard with a scoop that points forward for a ram air effect. Take your pick.
Old May 24, 2001 | 06:19 PM
Desert Pearl's Avatar
I poked mine through the splash guard so that my car can perform two functions. One, get me to work and back a little quicker and two, to sweep the streets! It also works good at sucking up small rodents! Mmmmmmmmm, Lunch!
Old May 24, 2001 | 06:46 PM
y2kse's Avatar
doublea
Jun 12, 2001 11:44 AM
MaxMoJo
Apr 4, 2001 12:51 PM
jayc5627
Mar 31, 2001 08:43 AM
thorizeen
Mar 13, 2001 11:10 AM
