For those with the OSCAI please read!!!
Old May 25, 2001 | 07:03 AM
edadams's Avatar
For those with the OSCAI, Yesterday while driving my car started to make a horrible pinging noise. The symptoms were like having bad gasoline. The car was missing and pinging and runnning like s**t. Anyway I stopped to look under the hood and noticed the little sliding ring that attaches the intake scoop to the air box had slid back and was allowing air to enter without passing by the sensor.I'm not certain if the oscai tubing and other components caused the tube to pull away from the airbox or if it was poor engineering on nissans behalf. The air was sucking in around the 2" gap between the two plastic parts. After sliding the ring back into the proper position the car ran perfect. I can't believe a pos litle piece plastic could inflict so much headache. I put two screws into the plastic ring to prevent any further movement. Hope this will work.
Old May 25, 2001 | 07:06 AM
punkdork's Avatar
Great info.. thanks
Old May 25, 2001 | 07:08 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Pinging = bad
Good thing you found the problem and fixed it right away.
Old May 25, 2001 | 07:50 AM
y2kse's Avatar
Two words: Heat Soak.
Screws work. Plastic ties work as well. And your OSCAI had nothing to do with it.
Old May 25, 2001 | 08:11 AM
UMD_MaxSE's Avatar
Got Bent?
That little sleeve was loose even before I messed with it. You can clamp it down like you said to fix that though....thanks for the heads up
Old May 25, 2001 | 08:17 AM
edadams's Avatar
Must be Nissan engineering....
Old May 25, 2001 | 08:23 AM
punkdork's Avatar
Nissan Engineering... reminds me of Military Intelligence... oxymorons
Old May 25, 2001 | 08:26 AM
bcannon's Avatar
ARe you guys talking about the rectangular sleeve that slips on the air box after the L tube? I took the screw off my air intake, just to mess around and see how the OSCAI would work (the L tube fell right off, it was a byatch putting it back). Anyway, the rectangular sleeve is only attached it seems by having everything lined up and having the intake screwed in.
Old May 25, 2001 | 08:31 AM
y2kse's Avatar
Yep! It slides on the airbox and is held in place by your Higher Power!
Old May 25, 2001 | 12:03 PM
edadams's Avatar
mclasser
22
Nov 12, 2020 01:58 PM
chisam14
Nov 6, 2018 08:56 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
