Kegs and Maximas...don't do it
Old Sep 9, 2005 | 04:39 PM
Pri63's Avatar
Well as the title says...Here's the results of transporting numerous kegs back and forth from the store to my apt. I'm open for suggests for repair.
Those spots are from oil(Mobil 1 that leaked!)
Old Sep 9, 2005 | 04:46 PM
MrGone's Avatar
just make a new one out of MDF or something. That stock one is a joke
Old Sep 9, 2005 | 05:47 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i agree. it is time for a trip to lowes/home depot. when i was out at maxus this year, cattman had his version of a trunk holder up thingamabob. i do not recall the cost but if you wanted something simple then use the oem as a outline for an mdf replacement.
Old Sep 9, 2005 | 05:52 PM
OOmaxSE's Avatar
care to share what MDF is? my trunk board has been messed up from the previous owner... i'm down to make a board for my trunk. 'cept i want the carpet layout in the trunk. SON!
Old Sep 9, 2005 | 05:55 PM
sloppymax's Avatar
best way i know would be to describe it as reinforced/stronger cardboard. it would not be as strong as say a 2x4 but certainly would support more weight than the weak/cheaper than cardboard one.
Old Sep 9, 2005 | 06:03 PM
OOmaxSE's Avatar
i'm ALL IN if that's the case. how much tho?
Old Sep 9, 2005 | 06:07 PM
big_bogus's Avatar
MDF = Medium Density Fibeerboard.
I would use Pressure treated Plywood. Semi expensive, but good for a trunk. Glue carpet to it and it looks awesome!!
Old Sep 9, 2005 | 06:30 PM
Bluesbrekr's Avatar
Doctorate in Detailing
I saw the Cattman trunk board at Maxus also. The one Brian has was for a 4th gen. It was very sturdy, made of a plastic composite I believe. IIRC it was about $85. Not cheap, but worth it for those that don't want to make their own.
For mine, I cut a piece of 1/4 inch plywood to the shape of the OEM board. I used Gorilla glue to attach it. Turned out very sturdy.
Old Sep 9, 2005 | 07:45 PM
2k1Maxdrvr's Avatar
I just went to Lowe's and got some thin particleboard or something like that traced my damaged one put the carpet over it and was done with it, has worked great for about 4 mos now
Old Sep 9, 2005 | 08:28 PM
Lytheum's Avatar
i need to do this too...my sub box sits all tilted because the stock piece of carboard is mangled up. just been to lazy. i even have a sheet of mdf sitting right next to me.
Old Sep 9, 2005 | 09:16 PM
Darius's Avatar
I got some plywood and made my own... put hinges so i could still access the spare without taking the subs out.
Drilled in a handle
Here's the hinges
finished product. Cut a hole in the carpet for the handle.
Old Sep 9, 2005 | 10:06 PM
walec05's Avatar
nice i need to make one for my altima. mine cracked in half. damn subs are so heavy.
Old Sep 9, 2005 | 10:11 PM
Nomad's Avatar
if u wanna stay stock check this out: http://www.trademotion.com/partlocat...=3&catalogid=2
Old Sep 10, 2005 | 08:23 AM
chr0nos's Avatar
darius, i like your work. i think i may have to do somethign like that for my other car. it has a big-a$$ sub box in the trunk.
Old Sep 10, 2005 | 08:33 AM
OOmaxSE's Avatar
i threw my trunk liner thing out because it was so badly bent and deformed... now i have no reference when custom making the new board
Old Sep 10, 2005 | 09:10 AM
big_bogus's Avatar
The trunk carpet can be used as a template also.
Old Sep 10, 2005 | 10:12 AM
OOmaxSE's Avatar
.....TRUE!
Old Sep 11, 2005 | 05:53 AM
djfrestyl's Avatar
Suspension Yoda
13inch radius with the top right hand corner squared off.
Make a recessed box about 3 inch per side cubed in the middle and voila.
http://eden.rutgers.edu/~nbalani/tru...g/CIMG1004.JPG
Old Sep 11, 2005 | 07:51 AM
UGAd13's Avatar
fix your sig. it's too damn long.
Old Sep 11, 2005 | 08:49 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
Finish off your trunk with a 03 Maxima trunk mat- its nicely carpeted like the factory floor mats and has a cool Maxima embroided into it, I think I paid 30 for mine from Nissan. BTW that piece of cardboard that sits in the trunk is like 80 bux from Nissan- I was hauling wood in the trunk of my Maxima few years back for some camp fire and the trunk needed serious overhaul after that.
Old Sep 11, 2005 | 05:53 PM
aussie983's Avatar
They need to start making something like this for you guys
http://www.paradox-systems.com/produ...products_id=64
I transport buckets of rocks for my job occasionally and mines gonna end up like that too hahaha. Im seriously considering getting that diamond plate mat.
Old Sep 11, 2005 | 06:51 PM
siren001's Avatar
is the Diamond plate mat for the 01 can be made for the 01? mines destroyed from tools and subs.
Old Sep 12, 2005 | 01:20 PM
aussie983's Avatar
I don't know. You'd have to ask the guy who runs paradox systems, who is also a member of the org, although i forgot who that is.
Old Sep 12, 2005 | 01:34 PM
deftpunk's Avatar
My trunk board is all caved in too..........after transporting a couple stiffs in there. joking! It's definitely only made for light duty. You guys have me thinking about making my own now.........shame on all of you.
Old Sep 12, 2005 | 02:00 PM
NmexMAX's Avatar
dot dot dot ...
So f'ucking true ....
Old Sep 12, 2005 | 06:05 PM
BLUEMAX01SE's Avatar
Dude never mind the trunk!, When are you having a KEG party for us ORGERS at your place?
Old Sep 12, 2005 | 06:54 PM
gaby617's Avatar
30 bucks! where is this, my local dealer is charging 190 and a local salvage yard is charging 100. i exhausted numerous junkyards and cant find any 00-03 maximas, did find a 04 pretty smashed, i spilled lime green paint on mines and its a real eye soar. i want to replace the mat before putting in my box.
Old Sep 12, 2005 | 07:02 PM
Fr33way™'s Avatar
Wild for Width
mine bends in when I have textbooks in there for a 20 min drive
I always have to put stuff on the sides
Old Sep 12, 2005 | 08:21 PM
gtr_rider's Avatar
192.168.1.1
MDF replacement works perfectly, and I used some Lbrackets to make it function like the stock one.
MaximaMan
Jun 16, 2005 04:41 AM
gtmuggs
Feb 18, 2005 03:30 PM
soccstv
Oct 11, 2004 06:58 PM
