Installed my Frakencar intake...but problem!!!
Old Sep 9, 2005 | 05:46 PM
n3985's Avatar
大陆弟弟
This afternoon I installed my Frankencar + Apex'i filter intake. Install was smooth, although that bolt that holds the stock airbox behind the battery was a pain to get to. Finished installing and tightening everything, including the bracket from the MAF to the where the shock/strut is. BUT, when I drive around, such as cruising at 1000-2500rpm, I hear this RAPID duh-duh-duh-duh sound. Also hear it when I come to a stop, and when I go past 2500rpm along with the awesome growl. Any ideas what the problem could be? I was looking at the AM600 MAF and noticed that there was a tiny thin wire in the middle, which looked fragile and def could break if too much vibration exist. Could it be the bracket making the noise? Or the air filter touching the engine bay? There is maybe 1-2mm of space between my filter and the engine bay. I associate the noise with vibration, and knowing the history of the MAF and the thin little wire...must stop before I shell out $500 for a ne MAF. Thanks for the help!
Old Sep 9, 2005 | 06:03 PM
99 SE-L
I dont think the wire broke, If you diddint drop the MAF or got oil on it should be fine, but the noise i have no idea mb when u acclerate the filter moves and hits the chassis
Old Sep 9, 2005 | 06:07 PM
n3985's Avatar
大陆弟弟
But isnt one of the main causes of MAF failure is due to too much vibration? Hence the need for the little bracket. So then if my filter is moving too much...how can I stop it?
Old Sep 9, 2005 | 06:17 PM
99 SE-L
Is the filter moving? if so dosent franken car inlude a bracket to keep the midpipe along with the filter secure ,so it wont travel and since you said yours is very close to the fender it is probably touching it when you acclerate.
Old Sep 9, 2005 | 06:24 PM
n3985's Avatar
大陆弟弟
I said the filter is 1-2mm away from the engine bay. And that I secured the bracket and every connection. And no, the filter is not loose.
Old Sep 9, 2005 | 06:30 PM
99 SE-L
Oh ok Iam not sure then
Old Sep 9, 2005 | 06:33 PM
n3985's Avatar
大陆弟弟
But thanks for trying.
Old Sep 9, 2005 | 09:18 PM
Shogunsc4's Avatar
glad to hear you have the FC intake installed...but be extremely careful, I blew 4 MAFs from vibration. The thin wire in the MAF is the thermistor wire, they will not break loose from vibration. Make sure you space the parts out with the couplers (for example...dont let there be contact between the TB and the midpipe). As for the noise you are getting...I think it is just the filter vibration against the hood.
Old Sep 9, 2005 | 09:26 PM
DrKlop's Avatar
Driving is the next best thing
what's a TB?
Shogunsc4's Avatar
TB=throttle body
Old Sep 9, 2005 | 09:29 PM
DrKlop's Avatar
Originally Posted by Shogunsc4
TB=throttle body
gutcha lol
Old Sep 9, 2005 | 10:53 PM
MacAlert's Avatar
Ok, the MAFs do not die from vibration. I dropped my intake tude with the MAF inside off my kitchen counter and nothing happened. I must have been lucky or vibration is not the cause of a dead MAF.
Old Sep 10, 2005 | 10:21 AM
cato's Avatar
A new MAF costs around $102, not $400. My Stealer said my MAF was bad and needed replacing to the tune of $400ish. I did a search here and found he was mistaken or lying to me. So I called up the parts department where the car was being repaired. Their own parts department quoted me $102 when the service advisor quoted me $400......go figure
Old Sep 10, 2005 | 10:26 AM
n3985's Avatar
大陆弟弟
You do know that a 5th gen MAF and a 5.5gen MAF are different right? The 5th gen one costs $100-200, the 5.5gen costs $400+
Old Sep 10, 2005 | 10:28 AM
n3985's Avatar
大陆弟弟
How can I fix this? Lower the filter a little? But how?
Old Sep 10, 2005 | 12:47 PM
n3985's Avatar
大陆弟弟
OK, from what I can hear, I think I fixed the problem. I bought 2 rubber grommets, and a metal washer, and put them under the bracket to give it a approx. half inch raise. So far no more rubbing air filter sound.
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Tha'-Max
Aug 30, 2015 01:14 AM
kirkhilles
Aug 8, 2015 10:53 AM
