Help with batery and brake light
Old Sep 9, 2005 | 08:13 PM
theMax's Avatar
My brake and battery lights on the dash are comming on and off.
They both come on and go off at the same time. I took the car to autozone and they said the battery was low but the alternator checled out fine. I got the battery charged but the lights came back on 3 days later. They also said the battery checked out fine.
I have 41K on the car and a optima red top a few months old, also a UDP. Anyone have similar problems or can suggest a solution?
Old Sep 9, 2005 | 08:45 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i had the same thing. it took about a week and half before the alternator went out. it showed it was charging fine at first even after lights initially came but it stopped charging shortly after.
Old Sep 9, 2005 | 08:48 PM
theMax's Avatar
Did you do the repair yourself? I priced an alternator at autozone for $279, ouch!
Old Sep 9, 2005 | 08:52 PM
sloppymax's Avatar
i picked one up at a local alternator/starter shop. i think i paid $155 after $20 core return. it was a reman just like the one autozone, advance auto, etc would carry. i paid SR20DEN to replace mine since he was doing some other work to the car.
Old Sep 11, 2005 | 06:01 PM
theMax's Avatar
Anyone know how hard it is to replace the alternator? I've repaced the belts and it looks tight in there.
Old Sep 11, 2005 | 10:20 PM
terryKS's Avatar
Here's a link to R&R alternator I used:
http://www.motorvate.ca/mvp.php/500
I had the exact same problem with the lights on my 01 AE. Alternator failed me totallly after about 2 weeks. As I was driving home, gauges started acting funny, stereo turned off. I knew that batt was about dead, just hoping to make it home! As I pulled in my driveway the Max died. Typical Nissan, didn't leave me stranded!
Not a bad job to replace. Took me about and hour and a half to remove and the same to reinstall. Hardest part seemed to be feeding the alternator to its location(its a little tight).
I opted to have my alt. rebuilt locally. I have found in the past that the rebuilt alt & starters these days dont seem to be QC'd very well. More often than not, Ive had to take 1 or 2 alternators back before I got a good one. This is my opinion on this matter!!
It cost me $100 to have new bearing/bushings & regulator. If you go to the parts store and get a rebuilt I highly recommend you have them put it on their test machine and test under a load before taking it home. It isn't a bad job to do but I'd of been really upset if I got it all back together and they gave me a bad alternator(believe me its happened before). Just my .02!!
Best of luck!
Old Sep 12, 2005 | 06:28 PM
theMax's Avatar
Did you remove the rad to get the alternator out?
Also, 3 of us in this post have AE's, is our alternator different?
Old Sep 12, 2005 | 07:37 PM
sloppymax's Avatar
i only found 1 part number in nissan's fast parts cd. we did not have to remove the radiator to change the alternator.
Old Sep 12, 2005 | 07:48 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
it is an easy job... just need patience. Call autozone you can get one for 200 lifetime... good luck, follow the motovate link abpve and you are good to go....
Old Sep 12, 2005 | 08:21 PM
Whtmax'01's Avatar
I had alternator replaced for $250 including labor. i watched the mechanic do the install, it didnt seem hard , he took off belts, then ac compressor and then finally the alternator. I think it took 20 min to take off the parts , and same amount to put back on.
Old Sep 12, 2005 | 10:57 PM
nissanluva's Avatar
Had to replace mine on my AE a couple of weeks ago. Had it done at Nissan dealer. Bill came to $433 - luckily I was still under extended warranty so I only paid my deductible. I saw 1 other person had theirs fail at almost exactly the same mileage as mine did - 31K..... Now my CEL is on. 2 problems in 1 month Thank God for my Civic
Old Sep 13, 2005 | 08:02 AM
terryKS's Avatar
No I didnt remove the radiator, no need for that. You just remove the fans & fan shroud(one piece). All thats involved with that is, 2 bolts on top of rad. support, unplug two wire connectors, unhook your top radiator hose and lift the fans out in one piece. Takes about 4 minutes to remove.
You could maybe get away with not removing the fan. The only purpose is to give you more access while removing the alternator. Seems to me that it is well worth the couple extra minutes to remove the fans for the added room to work in though! HTH
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
