Need Help on TCM Reset
Old Sep 15, 2005 | 07:16 PM
Shogunsc4's Avatar
I followed the procedures from the sticky and for some reason it would not reset. I performed the procedures 5 times and cannot get the AT light to flash. I have done ECU reset and idle learn many times and worked but the TCM is giving me a hard time. Also, is the TCM similar to the ECU in which it will re-learn and re-adjust over times?
Old Sep 16, 2005 | 04:34 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if you are trying to get the tcm to learn to shift at redline then it will not work. there may be certain parameters that it will have to relearn after the reset but its defaulted to shift a certain rpm. the only way to change is have a program/software and some hardware interface and reprogram it.
Old Sep 17, 2005 | 10:36 PM
Shogunsc4's Avatar
actually I'm trying to get rid of that weird "rev bounce" when braking. I just found out that it is the tranny doing it. When the car is in 1st or 2nd...it acts normal but if it is in 3rd or D...it bounces around when slowing to a stop @ ~1k rpm. The tech told me that it is normal (he even showed me but mine is more pronounce). He mentioned that it was the tranny dropping from 3rd to 2nd and 1st gear causing it the rev up a bit. I was wondering if the TCM reset would help. One very important question...on the reset procedure...when it states "OFF", does it mean position 1 or 2 on the ignition? We have 0=lock, 1, 2=ACC, 3=ignition ON, 4=start. Does ignition OFF mean 1 or 2? because position 1 doesnt click in like 2 and 3 would.
Old Sep 17, 2005 | 11:50 PM
joebangaa's Avatar
won't do a thing...the car's are designed to downshift themselves to shorten braking distance
Old Sep 17, 2005 | 11:56 PM
Shogunsc4's Avatar
thats what I thought too but the rpm surges up ~200rpm making the car to lurge up a bit instead of shortening the distance
Old Sep 18, 2005 | 01:03 AM
NOCturnalI30's Avatar
Any way to keep it from starting at second gear when your at a quick stop not a complete stop like when u yield for some one
gigabyte
Jan 6, 2017 06:05 PM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 22, 2015 03:08 PM
vrajesh123
Sep 22, 2015 04:20 AM
Colossus
Sep 9, 2015 05:46 AM
