2k2 muffler problems
Old Sep 20, 2005 | 06:49 PM
jaykid806's Avatar
my 2k2 just got a new muffler from midas. it was wut there book says the car calls for. they put it on and everthing. looks about the same. i started it to leave and it still sounds like it has the hole. wuts the matter with my max. and do i have to spend the 300 for the nissan one to make it sound normal? and is there a aftermarket muffler that is as quiet as the stock but alot cheaper? help me i dont even like drivin the max with that louder sound? doesnt fell classy anymore
Old Sep 20, 2005 | 07:14 PM
NmexMAX's Avatar
dot dot dot ...
Check under the vehicle for exhaust leaks, tighten bolts etc . Common sense before running out and buying something that you're not sure is at fault.
Also, midas and all other muffler shops have replacements for mufflers, so what their book 'calls for' is still not up to OEM standards, only theirs ..
Check ebay for 2k+ mufflers for ~ 60$ ...
Old Sep 20, 2005 | 08:24 PM
jaykid806's Avatar
i want quiet mufflers not rice mufflers, are there any brand cheap to look for?
Old Sep 20, 2005 | 08:32 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
next time don't believe George Foreman.......
Old Sep 20, 2005 | 08:39 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Maybe check the 5th gen classified section and buy a used one.
Old Sep 26, 2005 | 08:04 AM
2002blackmax's Avatar
I have a 2002 SE and was just told by Midas that I needed a new muffler to fix a small leek at the flange that joins the centre pipe to the muffler pipe that goes in to the actual muffler. They wanted $380 (CDN) to replace the muffler. However, my actual muffler looked good and is stainless steel from the factory (as yours should have been) so I got another opinion from an exhaust repair shop that said the flange where I had the leak is a common weak spot on the Maxima as, for some strange reason, it is made of normal steel prone to rust as opposed to the rest of the exhaust system which is stainless. The long and short of it is he cut out the flange and welded a stainless steel sleeve between the two stainless pipes and said the exhaust (including the muffler) should last many, many more years since it is all now stainless steel. It also only cost $55 for the repair.
Mar 12, 2020 12:06 AM
Turbonut
46
Oct 21, 2015 08:28 PM
ajahearn
Sep 19, 2015 03:03 PM
slowlifer
Sep 8, 2015 05:53 AM
TheMafia
Sep 4, 2015 08:26 AM
