Bad knock sensor
Old Sep 20, 2005 | 08:51 PM
vq356sp's Avatar
El Mas Noob Del Org.
Bad knock sensor
hey guys would a bad knock sensor cause my ses light to come on? thanks in advance
Old Sep 20, 2005 | 09:45 PM
mtrai760's Avatar
'Trynna' is not a word
Yes it could. Pull your codes and find out.
Old Sep 21, 2005 | 07:31 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
esm states a bad knock sensor will not trip cel. typically the cel will go off but the code will not reference the knock sensor. this is why it is known as a ghost code. best way to see if it is working is monitor your timing.
Old Sep 21, 2005 | 09:39 AM
vq356sp's Avatar
thanks for the help
Old Sep 21, 2005 | 05:29 PM
BewstAdd1ct's Avatar
p0327 and p0328 are knock sensor codes. ECM will store a code but the MIL will not be turned on.
Old Oct 3, 2005 | 09:35 PM
jp_cout's Avatar
no code and a bad knock sensor...that's what happened to me...such a crappy performance with a bad knock sensor..I enjoy it since it's new...better low rpm power...
Old Oct 3, 2005 | 09:54 PM
panda_1's Avatar
so how do u know when its dead?
Old Oct 18, 2005 | 11:01 AM
vq356sp's Avatar
yah how do you know when its dead what exactly are the symptoms and where is this sensor located? thanks
Old Oct 18, 2005 | 11:39 AM
NmexMAX's Avatar
dot dot dot ...
.... KS is located on top of the block, under the IM ... looks easier to reach as compared to a 4g.
Old Oct 18, 2005 | 03:43 PM
Rayn4est's Avatar
I'd like to know too. My 1700-2000rpm knock has gotten significantly worse lately and when I had my car in for tranny fluid change they couldn't replicate it. It was raining and I couldn't replicate it either for the previous 3 days. As soon as the sun came out the knock was back. I think I just couldn't hear it during the rain. Thought it was a couple of tanks of bad gas..now I think it can't be.
Old Oct 18, 2005 | 03:46 PM
NmexMAX's Avatar
dot dot dot ...
1700-2000rpm
How can you tell since that's a very small range ... 300rpm ...
Old Oct 18, 2005 | 05:42 PM
cabernet's Avatar
What's the best price anyone has seen on a new sensor?
JRNissan wants $142 with free shipping. Lot to pay unless you know yours has gone bad.
Old Oct 18, 2005 | 05:46 PM
when you hear the knock, you look down and ck the RPM...
after 5 or 10 times you get an idea of when it happens most, and thats your range...
Old Oct 19, 2005 | 02:13 PM
Rayn4est's Avatar
Yup. There are/were several threads on the 1700-2000rpm knock.
Old Oct 20, 2005 | 11:07 AM
cabernet's Avatar
nissanpartswholesale.com $104.92 free shipping
http://catalog.nissanpartswholesale....ageField2.y=13
Old Oct 20, 2005 | 06:10 PM
panda_1's Avatar
out of curiousity whats the approx life expectancy of the KS? debating changing mine for shi&s and giggles.
Old Oct 20, 2005 | 08:37 PM
theoretically it should outlast the engine... nissan seems to have problems, for whatever reason
Old Nov 22, 2005 | 02:11 AM
panda_1's Avatar
i think im going to replace mine in the near future to avoid having to do it later on.
Old Nov 22, 2005 | 07:45 AM
MIXXMAX's Avatar
Wow! I hope mine doesn't go bad. Since owning a '95 before I got rid of it, I now scan my ECU for "ghost" codes (such as knock sensor) every once in a while. The knock sensor was a PIA to replace in the 4th gener's. I hope I don't have to replace one in my '00 SE anytime soon! So far, so good.
Old Dec 4, 2005 | 08:33 AM
okharren's Avatar
...has anyone on this thread replaced a KS on a 5th gen Maxima? I found pictures of KS location and replacement instructions on the 4th Gen thread but nothing on 5th Gen. I read previously that it's located under the IM but I can't see mine ... just wondering if the IM has to come off ... thx in advance.
Old Dec 4, 2005 | 07:13 PM
MIXXMAX's Avatar
I'm not sure who has, but the 5th gener knock sensors are not proned to go bad as compared to the 4th gener's. I replaced one in my '95 which was a PIA. You won't know if it's bad unless you run a scan on your ECU with an OBII scan tool, since the sensor is a "ghost code".
Old Dec 5, 2005 | 07:43 AM
Larrio's Avatar
The Definitive AE Master
the ones on the 4th gens tend to crack or split near the edges and eventually down the middle due to the high heat of where it sits in our engine bay (wedged between the V portion of our block and blocked by a IM)
I think 5th gens may have this problem also, but it just hasn't been widely apparent yet.
Old Oct 12, 2009 | 03:06 PM
ZGadson's Avatar
Yay! for bringing an almost 5 year old post back from the grave.
Question: Where do I find the knock sensor? Can anyone post a pic or diagram? I know exactly what it looks like, but I must be blind because I don't see it. (2002 i35)
Old Oct 12, 2009 | 03:42 PM
boris's Avatar
FRONT OF THE CAR
Old Nov 9, 2009 | 04:50 PM
ZGadson's Avatar
Not as easy as it looks apparently. Does getting to the sensor require removal of the intake manifold?
Old Nov 10, 2009 | 12:08 PM
ridinwitha35's Avatar
No. But if you take off the upper AND lower manifold it'd be super easy.
Grab a long extension & u-joint & be done:
Old Nov 10, 2009 | 08:33 PM
ghostrider17's Avatar
Anybody actually replace the KS after having the "knock" and have it resolve the issue???
I'm hoping this could be the end of this stupid issue!!
gr
Old Nov 10, 2009 | 08:41 PM
Majestic Ken's Avatar
no problem at all here but i grounded mine to the battery tray
Old Nov 11, 2009 | 05:38 AM
What do you mean "grounded it to the battery tray"?
Grounded what?
Why?
gr
bbsitum
Sep 6, 2019 07:31 PM
ballerchris510
Sep 23, 2015 08:46 PM
ballerchris510
Sep 11, 2015 05:29 PM
