Anyone make a Torsen diff. for the 5.5 gen?
Old Sep 29, 2005 | 07:45 PM
MaxesRule's Avatar
Does anyone make a Torsen differential for the 5.5 gen? Something similar to a Quaife ATB diff. is what I'm looking for.
I'm not able to search and I've already googled it with no success, so don't bother flaming me.
Any/all help in this matter is appreciated! Thanks much.
Old Sep 29, 2005 | 07:55 PM
BewstAdd1ct's Avatar
helical = torsen, AFAIK...
stock unit. yay for 5.5gens...
Old Sep 29, 2005 | 08:59 PM
MaxesRule's Avatar
Are you sure that helical = Torsen (tor-que sen-sing)?
Does the stock diff. apportion torque left to right according to available traction in real-time/before actual wheel-slippage occurs like the Quaife does?
Old Sep 29, 2005 | 09:45 PM
bigEL's Avatar
I believe that is correct. Torsen is just one company's brand name for the HLSD. Prior to the 5.5 gens, the LSDs were of the viscous type.
Old Sep 29, 2005 | 09:53 PM
MaxesRule's Avatar
Really? First I thought they were called ATB diffs like Quaife's automatic torque biasing diff., then I learned that Quaife was just a brand.
Now I'm being told that they're called Torsen type diffs. Hopefully I've got it right this time! lol
So for they record, they're called HLSD's (for helical limited slip diffs), right?
Thanx much!
Any personal experience with it?
Old Sep 30, 2005 | 05:52 AM
jmt9n's Avatar
With the OEM crappy tires, it's easy to tell that the HLSD is there when you take off quickly in wet conditions in first gear.
Old Sep 30, 2005 | 06:08 AM
MaxesRule's Avatar
Really? How so? What does the car feel like?
Old Sep 30, 2005 | 04:50 PM
i could tell you by looking at it if its torsen/zexel... ive got one for my truck sitting in my kitchen
Old Oct 1, 2005 | 12:03 AM
bigEL's Avatar
Are you stating that as a fact borne from personal experience or mere conjecture?
Theoretically, if you applied power to a HLSD in slippery conditions, it will act like an open diff. You wouldn't be able to tell the difference. The reason is because the HLSD is a torque-sensing system. It reacts to torque loads placed on the system, which binds up a set of gears riding on a helical bias, which binds up the diff. What that means to you is that if you lose traction in one or both wheels, the HLSD no longer senses any torque on the system and the gears won't lock up the diff. This is the opposite of a VLSD, which senses inequalities in wheel speed. These will lock up in slippery conditions if one wheel lose traction, but not if both wheels slip at the same rate.
Old Oct 1, 2005 | 01:02 AM
bigEL's Avatar
Thanx much!
For practical purposes, all three terms are synonymous. HLSD is the generic term. Quaife decided to call their version ATB, while Zexel decided to call theirs Torsen. Many other companies make HLSDs under their own band names. They all use helical gears and operate on the same or similar principles. Therefore, unless you are referring to a specific company's product, you should technically call them HLSDs. But brand names have become so commonplace that most people will know what you are talking about. It's not a big deal. Call them whatever you want. Just don't mix up the HLSD with other LSDs, like the viscous, spring, clutch types, etc.
Old Oct 1, 2005 | 05:02 PM
Stereodude's Avatar
That's not entirely true. If there is no resistance (like the car jacked in the air) then it will act like an open diff, but as long as there is a little bit of resistance on the wheel that's on the slippery stuff the gears will engage and route the torque accordingly.
Old Oct 2, 2005 | 11:08 AM
chr0nos's Avatar
Torsen is a TYPE of lsd.
here are some linx explaining tis stuff:
http://www.houseofthud.com/differentials.htm
http://www.answerbag.com/q_view.php/1737
http://web.mit.edu/2.972/www/reports...ferential.html
Old Oct 3, 2005 | 07:35 AM
jmt9n's Avatar
Personal experience.
Old Oct 3, 2005 | 07:50 AM
jmt9n's Avatar
It's not easy to describe the feeling (for me at least). Generally, one tire slips for a split second and then stops because the HLSD kicks in. I've only done it a few times on accident (usually on hills when it's wet), but I can tell a difference compared to a car without one. You can also tell when accelerating rapidly in curves.
Old Oct 3, 2005 | 08:04 AM
bigEL's Avatar
That's why I said "theoretically." Manufacturers can design in different degrees of play before the LSD kicks in. That's why I asked. I wasn't trying to be a wiseguy.
Old Oct 3, 2005 | 07:24 PM
thats called torque bias.
THANK you...
Torsen bought zexel, or the other way around. the name is synonymous with a helical gear locking differential. they invented it, AFAIK...
Old Oct 4, 2005 | 05:49 AM
d00df00d's Avatar
Old enuf to pick his own gears
Torsen = Torque Sensing
Helical = The gears in the diff are cut in a helical pattern
ATB = Automatic Torque Biasing
LSD = A diff that doesn't let one wheel spin faster than the other by more than a certain amount
Any diff labelled "Quaife", "ATB", "Torsen", or "Helical" does the same thing: It acts like an open diff (good for turn-in) until one wheel encounters more resistance than the other, at which point it takes torque away from the faster-spinning wheel and channels it to the slower-spinning wheel. Some are better than others, but they all have helical gears and they all redirect torque. They can also kill torque steer, and they will not die for a very, very long time.
This is different from a plain LSD, like the viscous (VLSD) and clutch-type (e.g. Cusco, Kaaz, Phantom Grip) diffs. Those will prevent one wheel from spinning out of control by limiting the amount that one wheel can spin without the other. They won't redirect torque, they can compromise turn-in, and they won't help torque steer much, but they're much simpler (i.e. cheaper) and can be less intrusive for things like drifting.
NEITHER OF THESE TYPES IS ACTUALLY A "LOCKING" DIFFERENTIAL, no matter what anyone says. "Locking" is just a term that people throw around so they don't have to keep track of all the different kinds of non-open diffs. The diff types above will prevent traction loss, but they will NOT lock the wheels so that they spin together at exactly the same speed -- which is good, because that'd kinda suck for anything except going in a perfectly straight line on really bad surfaces.
Old Oct 4, 2005 | 07:17 PM
and rock climbing
Old Oct 5, 2005 | 12:06 AM
d00df00d's Avatar
Yes. Yes indeed.
Old Oct 5, 2005 | 06:00 AM
boondoxmax's Avatar
Makes sense cause i notice that i don't really have the tq steer problem i had with my auto 02 which was pretty bad on fast take offs. But my 6 speed w/HLSD can take of fast w/ almost no tq steer. Also when corner at high speed my 6 speed feels very stable. Now that i've driven both non-hlsd and hlsd equiped cars i'd have to say that hlsd is a must especially on manual tranny cars......
Old Oct 27, 2007 | 09:04 AM
BKmax20003's Avatar
H Limited slip for automatics
I have a 2003 max automatic and no LSD. Is there a way to add LSD to the car? Who would sell it?
Old Oct 27, 2007 | 09:23 AM
Stardust's Avatar
F---ing Kangaroos
Follow the rules, http://forums.maxima.org/showthread.php?t=365289
Old Oct 27, 2007 | 12:18 PM
boondoxmax's Avatar
The only time I really notice they HLSD is when I am cornering really fast and I am able to keep giving the car gas thru the corner while my old 02 would feel sloppy.. So it helps you corner fast for sure
Old Oct 27, 2007 | 03:55 PM
Stardust's Avatar
F---ing Kangaroos
I know I'm getting ready to comment on a 2yo post, bite me.
:stfu: limited slips don't "kick in"
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MaxStock
Aug 14, 2015 10:01 PM
MaxStock
Aug 12, 2015 08:33 AM
