Strange Noise when turning wheel to the left, Any Idea?
Old Oct 1, 2005 | 08:05 PM
GreyGoose's Avatar
I get a weird grinding noise when I turn my wheel all the way to the left and if i am turn out of a steep driveway or any kind of incline. anyone have this issue.
Old Oct 1, 2005 | 09:26 PM
MoCoMax's Avatar
Mine just started doing this recently. Haven't had much time to check, but the steering doesn't seem to be affected in any way. I was thinking sway bar link, or something else in the front suspension.
Old Oct 1, 2005 | 10:36 PM
OHH NOES's Avatar
6spd Swapped
Check your CV-Joint. Look for leaking grease around the boot.
Old Oct 1, 2005 | 10:57 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
is this with the wheel turned all the way to MAX when turning ? If so, lube up your limiter studs that are part of the knuckle. There is a Bolt with a plastic cap (it wears off and falls of exposing just the bolt end) that hits the controll arm when turned all the way to left or right, this end needs to be lubricated or you will get grinding noises when going over bumps like driveway inclines and turning.
CV joint could make this noise, but not at this low of a speed- drive way speeds. My pass side axle would make a ratcheting noise when making left hand turns at higher speeds, and the boot looked like new even with 100K miles. I ended up getting new axles and tranny thanx to Nissan for free.
Old Oct 2, 2005 | 12:33 AM
Maxima 5-0's Avatar
mine also makes the same grinding noise. hopefully some of those tips will help...
Old Oct 2, 2005 | 06:28 AM
MoCoMax's Avatar
In my case, yes. The noise occurs only at full left steering lock, and is more noticable/pronounced when going up/down a small incline like my driveway. In reverse, I'll occasionally hear a metallic 'crunk' sound when I hit the bottom of the incline.
Hondarydr
Dec 30, 2024 06:15 PM
alixc
Aug 11, 2020 01:48 PM
trasmadean
Feb 1, 2017 08:20 PM
official_style
Aug 29, 2015 10:10 AM
bc992164
Aug 26, 2015 12:19 PM
