"Thunking" noise
Old Oct 5, 2005 | 05:13 AM
chr0nos's Avatar
"Thunking" noise
I would like to know if anyone has had this problem before, or if you know what it may be.
This morning, I got in the car, and started driving. And I hear "thunk, thunk, thunk" noise. It almost sounds like a flat tire, but not as loud. The oscilations increase the faster I go, just like a flat tire. This makes me think that it's something in the rotating part of the car. I checked, and all my tires are fine. Anyway.... I got on the highway (reluctantly), and drove to work. The noise dissapeared. Maybe it will come back again, when the car is cold. I read something about bad wheel bearings happening more often with lowered cars, so this may be my problem.
If anyone has experienced a similar issue, or if you guys have some ideas on what I can check, please let me know.
Old Oct 5, 2005 | 06:10 AM
Love_00_Max's Avatar
I get the same sounds when cold but have gotten used to it and don't bother. I have checked everything in the trunk, checked the dust shields etc. but nothing obvious.
Old Oct 5, 2005 | 06:43 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if it is the wheel bearing, you should have it checked before it could potentially destroy the hub.
Old Oct 5, 2005 | 06:49 AM
chr0nos's Avatar
i will today after work. this just started today, it's not cold, maybe 50° at night right now. could it be something needs to be greased, because the factory grease is getting thick, and does not lubricate properly until it warms up due to driving?
Old Oct 5, 2005 | 06:59 AM
Puppetmaster's Avatar
Yup.... and that's something you can check yourself... jack the car up, grab the top and bottom of the front tire and try to wiggle it, if there is excessive play, ya probably have bad bearings.
Old Oct 6, 2005 | 04:35 AM
phobix's Avatar
Wow! I just had the same problem start last week. When cold it sounds like a whirling metallic sound, as soon as the car warms up it is fine. In my case it sounds like it is coming from the rear drivers side. Is it possible that the rear wheel bearing is on the way out?
Old Oct 6, 2005 | 05:43 AM
chr0nos's Avatar
hmm, check for bearings and cv joints/boots.
i just found out that my front passenger cv boot was cut. i don't think this was making that noise, but i am glad i got under the car and inspected everything.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
