Okay Light in dash came on..
Old Oct 11, 2005 | 02:32 PM
swetcountrygrl's Avatar
I was driving down the road in my moms 2000 maxima and the check engine light came on and the the slip light came on. They stayed on. I turned the car off and then back on the check engine light only came back on. Turned car off again and no lights are on now. Do you think this is something I should worry about? Shop told me it could be in the plug?? Anyone had any suggustions?
Old Oct 11, 2005 | 04:24 PM
MIXXMAX's Avatar
Sounds like a coil issue to me. One or more of your coils may be bad and may need replacing. Wait for the SES to come on again and extract the code.
Old Oct 12, 2005 | 03:00 PM
BewstAdd1ct's Avatar
or... you could just ck the codes. if its cleared itself, oyul have to wait for it to trip again. may have just been a gas cap.
also, blue font sux
Old Oct 13, 2005 | 02:49 PM
Codes P1320,P0300, P1320
Okay we put the car on the machine and it came back with 3 codes
P1320
P0300
P1320
the guy that put it on the machine said it was in the fireing.
We re-placed the plugs and this is still happening.
When you start the car it misses really bad and when you go to take off it misses really bad?
Any help would be appericated!
Also would this make my slip light come on and the tcs light come on?
Old Oct 13, 2005 | 04:14 PM
MIXXMAX's Avatar
P1320
P0300
P1320
Replacing the plugs aren't going to do anything. It's a COIL issue. Replace all six coils. Make sure you buy the updated ones (ones with grey dot on them). And, yeah, the slip, TCS, and SES on at the same time means a coil issue--code P1320.
Old Oct 13, 2005 | 04:59 PM
dude? lol....
yea hun, you have a failed coil. replace one and then next one will fail later on... buy the updated coils, install... and youre done.
Old Oct 13, 2005 | 05:13 PM
MIXXMAX's Avatar
Originally Posted by BewstAdd1ct
dude? lol....
Oooops, I didn't realize her ID name. Sorry. I edited my post.
Old Oct 14, 2005 | 05:28 AM
So okay i replaced 5 cause they didnt have all six...the car has stopped missing...Do I need to reset the service engine light? Cause it stayed on but the rest of the lights went off...
Help
Old Oct 14, 2005 | 04:08 PM
it will reset itself after enough drive cycles without a fault... or the next time youre driving by autozone, you can have them clear it
Old Oct 15, 2005 | 12:52 AM
MIXXMAX's Avatar
Yes, clear the SES light. Once cleared, the car will go into "re-learn" phase. The sooner the better. It won't recognize the new change until it's cleared.
Old Oct 16, 2005 | 05:32 AM
Ok please help this is getting on my nerves...We replaced the coils and went to autozone to reset the light and it wont reset and its still thoughing the codes P1320
P0300??? Whats up with that?
Old Oct 18, 2005 | 03:13 PM
did you replace that 6th coil? did you check the connectors for the individual coils? did you check for wire chafing?
are all the coils plugged in correctly?
and OBDII is always in relearn, and has self healing capabilities. itll learn as soon as the fault is remedied, regardless of MIL status.
Old Oct 18, 2005 | 03:34 PM
montreal_speed's Avatar
That's exactly the same problem on my 2000 Maxima. But when I push the accelerator the rpm goes up and the gearbox doen't shfit up. I need to push a second time on that for shifting up..
How much for the coil replacement???? I have an extented garantee do you think it can help me to save money???
Old Oct 18, 2005 | 05:38 PM
yea, an extended powertrain warranty should cover the coils.
Old Oct 18, 2005 | 07:25 PM
upstatemax's Avatar
that sounds more like a TCM that needs to be reprogramed. Mine did the same thing and after the TCM was done, good as new.
Old Oct 18, 2005 | 07:31 PM
upstatemax's Avatar
You need to replace ALL OF THE COILS, knowing you current luck you did not replace the one that was bad.
As far as the TCM and Slip comming on, I had that problem when my ABS went bad (well my front two got chewwed to crap when I slammed my car on D2's and did not resecure them , thank god for extended warranties!!).
Old Oct 19, 2005 | 01:56 PM
Yes we replaced All the coils. ALL 6! But we took it to avanced auto to get them to reset it and they said it was still thoughing the codes. Okay now the light is back on and we took it to autozone and they tell me its a law to reset the SES light. So I made an App. At the local Maxima dealer to have it looked at tomorrow. 79.00 just to put it on the machine.
Old Oct 20, 2005 | 07:09 PM
there isnt a law to reset the light. unless its a local law, but then they would have documentation on it. even so, it doesnt seem reasonable... youre clearing potentially valuable freeze frame data as well.
pull off all of the coil connectors and check the connections, then try and clear the code again.
g/l
Old Oct 21, 2005 | 10:26 AM
zioes_00se's Avatar
My ses light came on last week and turned out to be a new cat-converter and ecu programming...thankfully my nissan dealership warranted the entire thing. Even with 60k on the car too.
Old Oct 22, 2005 | 02:10 PM
ya, emissions warranty is 8/80
Old Oct 23, 2005 | 10:19 AM
Okay this is what the Dealer ship said Friday...
Failure Code for TW catalyst failure monitored oxygen sensors and found both front and rear sensors are reading the same indicating failure had occured inside of both front pre catalysts checked and found engine control module could be reprogramed. When the light comes back on we will have to replace both front catalysts estimate $1675.
We got them to reset the SES light.. paid $118.00. Now the light just came back on. Do you think if we run the car like this its going to hurt the car? What should we do? What needs to be replace?
help!
Old Oct 23, 2005 | 10:27 AM
Italiano's Avatar
SWIFT_Navigator
wow, i see all these people from all over the country and then i see upstatemax from clifton park, lol.. small world.
Old Oct 23, 2005 | 04:35 PM
upstatemax's Avatar
Very few of us from this neck of the woods....
Old Oct 23, 2005 | 04:37 PM
upstatemax's Avatar
help!
get a cattman y-pipe... alot cheaper and it adds power. The pre-cats are in the y-pipe, so it will eliminate them, or if you want to do this the cheapest way possible, get an O2 simulator from O2simulator.com
Old Oct 24, 2005 | 07:05 AM
Italiano's Avatar
SWIFT_Navigator
this is true
Old Oct 24, 2005 | 04:49 PM
Okay how hard is a cattman y-pipe to put on?? And how much would one cost? And does this make the car louder or anything? Cause this is my moms car.
Old Oct 24, 2005 | 05:00 PM
upstatemax's Avatar
Not that hard to put on, you can have a shop do it for you if you want; Personally I would, doing exhaust work without a lift is a PIA.
The car will be a little louder because the pre-cats are gone... but it is not "loud", more like a tone difference.... I would think you could get the y-pipe and have it installed for under $500.
Old Oct 24, 2005 | 09:24 PM
what code was it? p0420, p0430?
how many miles on the car?
Old Oct 25, 2005 | 01:59 PM
Didnt Give a code...Just told us thats what it was.
It has 112,000 on it.
Old Oct 25, 2005 | 08:22 PM
if you payed for diagnosis, then they owe you all the information they found, including the code...
...meh, doesnt matter, its out of emissions warranty anyway. id get the y-pipe... and again, its a tine difference, and shell likely only hear the difference under heavy acceleration.
but if im not mistaken, you have to relocate the o2 sensors anyway... someone correct me if im wrong... but if im not, honestly the best way to fix this is with an o2 simulator...
Old Oct 26, 2005 | 06:11 AM
upstatemax's Avatar
Yeah you do, the two secondary sensors have to either be moved (PIA) or simulated... I have mine simulated and I have not had a problem yet. Cattman is now offering O2 sims when you buy y-pipes and headers I think. When you order it from then just ask.
Old Oct 26, 2005 | 03:58 PM
then the most reasonable fix is just to use a simulator.
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 6, 2015 10:42 AM
rnb754
Sep 14, 2015 11:39 PM
Maxima30
Sep 7, 2015 06:13 PM
