My foot is off the gas yet my engine still revs..
Old Oct 15, 2005 | 04:46 PM
acMAX's Avatar
I put my car in PARK and I noticed that my my rpms were going up as if my foot was still pressed on the gas.
I shut down the car and open up the hood to check out the throttle wire thingy (don't know what it's called so please bear with my ignorance).
When you push down on the gas, you know how the wire pulls on that metal thing which basically opens up the throttle? Well, sometime it's not going all the way back down when the gas is released.
So I kinda pulled the wire and sprayed a little WD40 on it to make sure that it moved properly and everything seems to be fine for now.
Anyone else experience this?
Or can anyone recommend what i should do to make sure this doesnt happen again?
Thanks in advance....
Old Oct 15, 2005 | 06:00 PM
mtnbikeair's Avatar
Its possible that your throttle cable is sticking. And the thing that opens up is called your throttle body just so you know.
Old Oct 15, 2005 | 06:01 PM
RockfordMax's Avatar
Back from the dead
hmm. might be a problem with your cruise control. try disconnecting it and see how it works
Old Oct 15, 2005 | 09:41 PM
acMAX's Avatar
it's not the cable that's sticking, I tested that. It's the part that the cable is actually pulling....
Old Oct 16, 2005 | 07:39 AM
mtnbikeair's Avatar
The butterfly?
Old Oct 16, 2005 | 12:39 PM
n3985's Avatar
大陆弟弟
Was the engine cold like you just started it? I noticed my car will rev to 1100 when first started, then drop back to 700ish for idle once warmed up.
Old Oct 18, 2005 | 03:40 PM
BewstAdd1ct's Avatar
remove intake duct and ck for carbon buildup on the throttle plate/body
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
wingnut2006
Sep 19, 2015 06:13 AM
slowlifer
Sep 8, 2015 05:53 AM
TheMafia
Sep 4, 2015 08:26 AM
