DDE remote on...HELP!!!!!
Old Oct 17, 2005 | 07:02 PM
Y2k2maxse's Avatar
i got the remote on for my DDes and I cant figure out what its telling me to do in the instructions. i know its telling me i have to hook it to an interior light but which one and which wire? can anybody help?
Old Oct 17, 2005 | 07:10 PM
Y2k2maxse's Avatar
update...OK now i get what they want me to do...use a wiretap and tap the white DDE wire into the 2 wires of an interior light...right? ok now what i dont understand is if its hooked up to that, can i still turn them on/off normally with the parking lights?
Old Oct 17, 2005 | 07:26 PM
irish44j's Avatar
retired moderator
perhaps I'm unclear about what the 'remote' is, but why would you need to turn them on/off via remote?
apologies in advance for the stupid question.
Old Oct 17, 2005 | 07:59 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
- Does this power wire go to a relay?
- What does this wire power?
- Why not just splice into the headlight power wire?
I would suggest splicing into the glovebox light, which will be quite the PITA to get to, but will have the least noticable effect on your interior lights, if any.
Old Oct 17, 2005 | 08:35 PM
Deckdout2's Avatar
Play with my balls
i think he wants his angel eyes to come on when he unlocks his car.....hence tapping into the dome light.
?....does this "remote" come with a relay attached?
Old Oct 18, 2005 | 02:30 PM
MaximaPolak's Avatar
Or the corner lights.
Old Nov 24, 2006 | 08:22 PM
JasTheAce12's Avatar
RadMax02
I'm going to try to resurrect this thread. I can't believe I can't find an answer to this original question anywhere online. The Umnitza DDEs come with a secondary remote wire, but I'm looking for input for what the best thing to do with this wire is. I'd really love to be able to turn them on as I approach and unlock the car. It sounds like the dome light is probably the best option. Can you wire directly to the relay? Anyone? This can't be too hard can it??
Old Nov 24, 2006 | 09:51 PM
n3985's Avatar
大陆弟弟
How it works on the BMW DDE kits is that the SPDT relay has a secondary trigger. The main trigger, slot 87 is used for something like the parking lights, which turns on the rings when the parking light switch is turned on. The secondary, slot 87a, taps into a source like the dome light, so when you press lock/unlock it'll again send a signal for the rings to be lit. In the case of E46s, it taps into the passenger footwell light, and in our case, our dome light wire.
Old Nov 29, 2006 | 02:57 PM
RadMax02
Where do you pick up the dome light wire? i've looked around a little bit.
Also, does this mean that whenever the dome light is on (whether it be switched on from inside the car, or from opening the car door) that the DDEs come on? Because that would be kinda silly. Whatever causes the blinkers to flash when you lock or unlock using the factory remote, must be able to be used to flash the DDEs too??
Old Nov 29, 2006 | 03:51 PM
n3985's Avatar
大陆弟弟
I wish I knew where the dome light wire is, I would have many uses for it. And yes, the rings will lit whenever the dome light is on.
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
