Alternator job
Old Oct 19, 2005 | 12:14 PM
Superman's Avatar
Alternator job
$325 for an alternator job...sound right?
Old Oct 19, 2005 | 12:45 PM
frankd121's Avatar
including altenator? or just labor alone?
Old Oct 19, 2005 | 01:05 PM
Superman's Avatar
including alternator
Old Oct 19, 2005 | 02:02 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
125 for labor.. damn do it yourelf and save the money.....
Old Oct 19, 2005 | 06:23 PM
vsamoylov
do it yourself. it is simple but you have to get the ac compressor out of the way to get the alternator out.
Old Oct 19, 2005 | 07:10 PM
Lontar1's Avatar
I did the search for you .. follow this link
http://www.motorvate.ca/mvp.php/500
Old Oct 20, 2005 | 12:50 AM
Superman's Avatar
thanks for your help guys, lontar thanks for doing the search.
Old Dec 1, 2005 | 09:39 AM
dobiegillis's Avatar
So is the part about $200?
Old Dec 1, 2005 | 11:17 AM
Whtmax'01's Avatar
I paid $210 for alternater and labor. The mechanic however never had to remove the fan to do the job.
Old Dec 1, 2005 | 03:37 PM
vsamoylov
because there is no point of removing the fans. alternator on maximas are above the ac. the only way to remove them is by removing the ac out of the way and taking the alternator out the throught the bottom. it will never come out through the top.
Old Dec 2, 2005 | 09:06 AM
ghostrider17's Avatar
Most alternators can be REBUILT for less than 1/2 the cost of a new unit.
If you do the removal yourself, which shouldn't be too difficult - you can take the unit to a rebuild shop and have them gut it for much less $$$.
I've never done this with a Max alt., but shouldn't be rocket science -- they're pretty much all the same.
let us know what you do.
gr
Old Dec 6, 2005 | 08:23 AM
The battery light stopped coming on so I'm not going to worry about it. The car starts and runs fine.
Old Dec 6, 2005 | 01:05 PM
Whtmax'01's Avatar
the battery light will go on and off many times before it finally stays on for good. Sometimes the alternator is good but the wiring to it may be all fried causing that light to turn on and off.
TallTom
57
Oct 14, 2025 05:16 PM
doctorpullit
Mar 29, 2016 11:08 AM
