Rear View Mirror Swap - Adding Compass
Old Oct 25, 2005 | 05:53 AM
Wheelie King's Avatar
I'm replacing a rearview mirror w/o compass with a rearview mirror w/compass on an 03 Maxima. The original mirror has auto dim but no compass. The new one has autodim and compass. I think the compass also tells temperature in the car. Is this a direct swap w/o the need for rewiring? I'm hoping I can just unplug one and replug the other. It looks like there is only a positive and negative wire going in on both.
I found a couple of these mirrors at a junkyard. PM me if you're interested in my spare.
Old Oct 25, 2005 | 06:52 AM
MarineMax's Avatar
I'm also intrested in doing this swap. I'm not sure about the wiring though. Are the plugs on both mirrors the same? If so and the number and color of wires are the same on both cars, then it should be a easy swap. I don't know though, I haven't done it yet.
Old Oct 25, 2005 | 07:01 AM
jeepik's Avatar
i did this swap with a mirror from my mom's Camry
it was plug and play
Old Oct 25, 2005 | 07:19 AM
ColdSHO's Avatar
witha compass and temp id liek one, how much shipped to 60102?
Old Oct 25, 2005 | 07:21 AM
TXT-1's Avatar
The OEM mirror with compass displays temperature as well?? I have that mirror and I don't think it does.
Old Oct 25, 2005 | 08:31 AM
MIXXMAX's Avatar
The autodim mirrors only have a connection for power and ground. If it has the compass function, wiring is the same because the compass is built into the mirror when powered. As far as the temp. readout, you must have a temp. probe/sensor wire to tap into. As far as our Max's go, anyone with auto climate control has this wire (Ambient wire). The sensor is located outside the car, underneath the front grill. You might want to get a wire diagram for the exact wire color for power. I don't believe the rear view mirrors are a direct swap, because I don't think they are pre-wired if your car didn't happen to come with one. Mine wasn't and I had to run wires up to the mirror when I upgraded mine.
Old Oct 25, 2005 | 08:43 AM
Teufelhunden's Avatar
my compass has the F for farenheight and the small circle, it shows when i start to mess with it. but it doesnt work, i looked in the manual but nothing about temp.
Old Oct 25, 2005 | 09:06 AM
03on18s's Avatar
i don't think there's a temp function on those mirrors. i would love to do that swap though. where did you get the new mirror with the compass function??
Old Oct 25, 2005 | 11:12 AM
jreddington3's Avatar
Nope. No temp function in the autodim/compass mirror. If you're getting a F and degree symbol it may be that Nissan, when buying the LED component, sourced out a generic display unit which might include those symbols. Buy there's no temp built into the mirror logic. I get ouside temp off the trip computer system. Inside temperature, I can set the climate control, but there's no feedback as to what the actual temperature is.
Good news. I believe the autodim/compass mirror is plug-n-play complatible with the autodim mirror. The compass fluxgate is inside the mirror and is powered from the same spot autodim is. Haven't done the swap myself but my '03 has the compass and my girlfriend's '02 does not. Was thinking about upgrading hers and compared our connectors. They look the same.
Old Oct 25, 2005 | 11:44 AM
chr0nos's Avatar
look in the manual. you have to set your location by driving in a cirle 15 times or something, or doing special programming to offset the degrees from greenwich time.
Old Oct 25, 2005 | 12:25 PM
bugbite77's Avatar
how much would one of these mirrors cost new? which maxima did they come standard in, i have an 02 SE and it just has the auto dim, is there a trim and year that it came standard or were all of them options?
Old Oct 25, 2005 | 12:28 PM
CKOTuHA's Avatar
I'm interested in one, can you pm me with price please.
Old Oct 25, 2005 | 12:41 PM
kobalt's Avatar
It would be nice to have a compass, mine is auto dim only as well. Im intereseted in buying, new or used.
Old Oct 25, 2005 | 01:02 PM
MarineMax's Avatar
Is there a way to tell just by looking without power applied if it has the compass? Ya know, just in case I find one at the junk yard I don't want to be buying one that I already have.
Old Oct 25, 2005 | 01:13 PM
TXT-1's Avatar
I think they came STD in the 03 Titaniums.
Old Oct 25, 2005 | 01:27 PM
03on18s's Avatar
i have an 03 SE and the mirror only has the auto dim function.
Old Oct 26, 2005 | 11:05 AM
bigsherv's Avatar
WHY IS NO ONE ANSWERING ABOUT WHERE TO GET THIS MIRROR.
i am done yelling now.
Old Oct 26, 2005 | 11:15 AM
TXT-1's Avatar
YOU'RE A TOOL! Ok, I'm done yelling now. :attention
Old Oct 26, 2005 | 11:47 AM
bg18461's Avatar
I did the swap, as txt-1 said, they were standard on 03 titanium's.
It is a plug and play with an 02 with just autodim.
However the temp doesn't work on the mirror because no probe wire is run up there.
I have auto climate, but to me, its not worth the trouble of running the wire to the mirror seeing as I already have a temp display in the instrument cluster...
I got it from car-part.com, it was like $50 bucks or something.
Old Oct 26, 2005 | 12:00 PM
boondoxmax's Avatar
my mirror doesn't have any temp display. I have an 03 titanium edition. just dims and has a compass.......to be honest i never use the dimming feature, but i love the compass!!!!!!
Old Oct 26, 2005 | 12:32 PM
ColdSHO's Avatar
all u fancy 02-03 guys, my 00 has nothign there so id have to wire everythign manually, which isnt a big deal, is the temp inside or outside, and can that be hooked up to the 00 auto climate control?
Old Oct 26, 2005 | 12:41 PM
jeepik's Avatar
look on ebay, also look into Toyota Camry mirrors, mine is from an 01 and looks the same and was a perfect fit and plugged right in
Old Oct 26, 2005 | 03:39 PM
MIXXMAX's Avatar
I don't think any of the 5th gener's came with a temp. readout on the rear view mirrors...just ones with or without autodim, and ones with autodim and compass. The ones with temp. readout are all aftermarket. You can find these on Ebay. Plenty of sellers sell these, but some are quite pricey. The 2k2- and 2k3's have the temp. readout in the guage cluster. Now, if you would happen to buy one aftermarket with the temp. display, all you have to do is tap into the ambient wire in the auto climate control A/C unit to read the temp (outside temp.) As far as the autodim function, all is needed is power and ground. It switches on automatically everytime you start the car (controlled by ignition). Now, you can bypass this function by switching it on/off manually by a switch, but if you power it by an unswitched 12V source, you may forget to turn it off when ignition is off, and possibly drain your battery. Now, my 2K SE didn't come with an autodim, but I did find one on Ebay and was really simple to wire up. I've been wanting the temp. and compass as well, but it seems that these mirrors are very popular because these people bid like crazy on these type of mirrors...in the $150+ range!
Old Oct 26, 2005 | 06:23 PM
bugbite77's Avatar
do you happen to have the direct link to the site you got it from, i looked all over car-part.com and couldnt find a site that had the mirror with the compass
Old Oct 27, 2005 | 05:19 AM
I got mine from a junkyard. I think they both came from gray 03s. I paid $45 each. You can tell the mirror has a compass because there is a little black rectangle in the miror to the right of center.
I'm going to do the swap this weekend. I'll post any problems. I don't expect any though. Thanks for the info on the temp display.
Old Oct 31, 2005 | 12:01 PM
Put the mirror in an 03 maxima this weekend. It was a very simple swap, one screw and unplug then plug the wiring. No problems. The compass works well with no need to do anything else. There is no temp display. All in all, it was a simple and worthwhile upgrade.
Old Oct 31, 2005 | 12:41 PM
bladerunr's Avatar
Damn straight! Wheelie helped me put the mirror in and it rocks! It took us all of 10 minutes to put in. The damn thing cost somewhere around $170 new, so for $55 it's an awesome upgrade.
Old Nov 5, 2005 | 05:23 AM
ZIPPIN's Avatar
Mauja He Mauja
i bought the autodim with compass. the harness coming out of the mirror has three wires. chocolate, black and green. black = gound, whats the green and chocolate one for???
also what did you guys use for the power one?
Old Nov 5, 2005 | 05:49 PM
JD2k2's Avatar
sweet body kit!!
Old Nov 5, 2005 | 05:57 PM
bladerunr's Avatar
It was plug & play. I disconnected the stock mirror and connected the compass mirror. The connectors are identical. I'm not sure which wire does what. I guess a volt meter would tell you.
JRod28
Feb 4, 2016 11:07 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
Quickgtp
Aug 27, 2015 02:13 PM
BobMax
Aug 19, 2015 04:39 PM
