2000 SE - Tires center wearing
Well, I am at the end (very end) of my third set of rubber. (2 summers (OEM RE92 "donuts-o-death" Michelin Pilot Sport A/S) , 1 winter (Bridgestone Blizzak WS-50)) Each of them lasted 3 years (7 months "summer", 5 months "winter")
Each and every one of them have center worn. I have tried high pressure, low pressure, Nissan recommended pressure, tire recommended pressure.
I drive kinda hard, equally in the corners as in start/stops. drive kinda fast, certainly faster than most.
Could this be more of a temperature (hot-pressure) issue rather than a cold-pressure issue. On summers, running 30-31psi cold I run 35-36psi hot. Generally, hot, fronts are 1-2psi higher than rears.
Any comments?
Any comments?
Suspension set-up?
A few details on your suspension set-up like lowering springs, increased rim size and after-market struts (adjustable, what setting?)? Conventional wisdom is that wearing out of the center = over-inflation.
Try 28 cold and see if the problem is mitigated. I know you said you've tried inflation though.
I'm not a suspension guru, but there are a lot of people on this board who are, and they can probably give you much more detail about alignment issues that may cause excessive center tread wear.
Mar 12, 2020 12:06 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
