gauges illumination light + tail lamps are out
All my gauges work ok (speedo, RPM, fuel, temp). my radio works fine, and so is my autoclimate system.
but the light that illuminates the instruments (what make the numbers bright during the night) is out.
my tail lamps are out also. I guess the problem is related, because it all happened at once.
In th FSM, for both illumination and tail lamps systems, its written "Power is supplied at all times to lighting switch terminal 11 through 10A Fuse (No. 60, located in the fuse and fusible link box)."
Is this only a fuse change? under the steering wheel? where exactly is no60?
or I am not getting it right?
Thanks for your help.
fastcarny
10-06-2015 10:42 AM
Maxima30
09-07-2015 06:13 PM
