Gen 2 Headers are teh r0xx0r! Dyno Results!
Old Oct 27, 2005 | 07:11 AM
rbrown81's Avatar
But why is teh Rum gone?
All
Just got the car dynoed this morning. Pulled 239.23 hp and 237.88 tq at the wheels on a 4th gear pull.
Strangely enough, these guys did 2 3rd gear pulls first, which did not yeild as high results, but very close.
Old Oct 27, 2005 | 07:58 AM
igzy's Avatar
I Know Kwaliti
To post images put the http link to it between like this: [img] link [/img]
Old Oct 27, 2005 | 08:04 AM
Puppetmaster's Avatar
Nice numbers.... you have PM....
Old Oct 27, 2005 | 08:05 AM
SixxOne's Avatar
What are your other mods?
Old Oct 27, 2005 | 08:07 AM
I think he has an Injen and Cattman cat-back....
Old Oct 27, 2005 | 08:44 AM
Deckdout2's Avatar
Play with my balls
sounds like you had a pretty nice pull. can you get those images up, or still need help?
Old Oct 27, 2005 | 08:50 AM
joebangaa's Avatar
oooo i want... post!!
Old Oct 27, 2005 | 09:38 AM
rbrown81's Avatar
My setup used to be injen... got rid of it and put in a Berk. Much better! I like having my low end back!
The numbers look odd because the 1st 2 runs in blue and green were 3rd gear pulls. They did the 3rd pull in 4th gear and we saw some very nice results with that. Kinda wished they had done all the pulls in 4th gear.
For a bunch of guys who love Evo's and STI's, they sure loved the sound of my car, not to mention the G35c Rims
Old Oct 27, 2005 | 10:28 AM
jimmycapp's Avatar
Nice Numbers
Those are uncorrected though. Right?
James
Old Oct 27, 2005 | 10:45 AM
NYPD-Arnold's Avatar
Z
TUNE THEM! Get yourself an SAFCII and advance your timing +2 to BTDC17.
Old Oct 27, 2005 | 11:14 AM
Originally Posted by jimmycapp
Nice Numbers
Seems like it... so that means with SAE correction they should be a tad lower right?
Got the AFR chart?
Old Oct 27, 2005 | 11:26 AM
6spd_Hayes's Avatar
FYI...
Gear Ratios: RS6F51A
1st-------3.153
2nd-------1.944
3rd-------1.392
4th-------1.055
5th-------0.809
6th-------0.630
Rev-------3.002
4th is the closest 1:1 ratio so you want to dyno in 4th gear.
**Edited** I swapped some numbers up on 3rd gear. My dislexia.. sorry. Fixed now.
Old Oct 27, 2005 | 11:50 AM
pxh1984's Avatar
I'm completely in the dark on this one, but what are the gen 2 headers?
Old Oct 27, 2005 | 11:52 AM
Cattman's new batch (2nd generation) of headers.
Old Oct 27, 2005 | 12:16 PM
Blu's Avatar
Blu
the tits
posted the SAE numbers please, im guessing 230whp corrected.
Old Oct 27, 2005 | 12:30 PM
steven88's Avatar
Need A Light?
Do you have the run files?
Old Oct 27, 2005 | 12:36 PM
SR20DEN's Avatar
VQ Wizard
All
Where is the baseline? Where are the SAE numbers?
Originally Posted by 6spd_Hayes
FYI...
1st-------3.153
2nd-------1.944
3rd-------1.932
4th-------1.055
5th-------0.809
6th-------0.630
Rev-------3.002
Wow 1mph difference between 2nd and 3rd?
Old Oct 27, 2005 | 12:39 PM
rbrown81's Avatar
Did not get the run files. They only gave me the run sheet. SAE corrected I would assume is probably 235 approx.
Nice numbers, but I am still pissed that my exhaust is rattling! Argh!
I did not have time to get a baseline done.
Old Oct 27, 2005 | 12:45 PM
steven88's Avatar
Need A Light?
sweeT! now can somebody compare this dyno with a gen1 dyno with the same mods? to prove that these cattmangz gain more mid-range
we already know peak #s haven't changed much...235whp sae seems to be the magic # with i/h/e (whether gen1 or gen2)
Old Oct 27, 2005 | 12:58 PM
03BlkSETE's Avatar
Strong numbers.
If you don't mind can you please get the SAE numbers so a better comparison can be made. One more thing, what kind of dyno was this, Dynojet?
6spd_Hayes's Avatar
I fixed the problem. My dislexia kicked in. 3rd should be 1.392 ratio.
Old Oct 27, 2005 | 01:01 PM
NmexMAX's Avatar
dot dot dot ...
Run files .. ... Sweet #'s .... VI is working
Old Oct 27, 2005 | 01:02 PM
Deckdout2's Avatar
Play with my balls
i don't think he got a baseline dyno.
Old Oct 27, 2005 | 01:05 PM
rbrown81's Avatar
Yes, it is a dynojet.
I have sent an email asking for the run files. I will hopefully have them by tomorrow.
My mods... check my sig!
Old Oct 27, 2005 | 01:43 PM
rbrown81's Avatar
I have a UDP to be installed, and I will be doing a timing advance. How much will I see with the SAFCII?
Old Oct 27, 2005 | 01:44 PM
NmexMAX's Avatar
dot dot dot ...
8-12whp.....
Old Oct 27, 2005 | 01:55 PM
rbrown81's Avatar
Any dangers of the AFC tune to the engine. Known code pulling?
Old Oct 27, 2005 | 01:57 PM
NmexMAX's Avatar
dot dot dot ...
Code pulling
Just don't tune for 18:1
Old Oct 27, 2005 | 02:23 PM
rbrown81's Avatar
Originally Posted by NmexMAX
Code pulling
Lol... I wont be doing that, I dont want to crack my block!
Anyone know how much power you can gain from exhaust scavenging? Header Wrap and whatnot?
Old Oct 27, 2005 | 02:30 PM
NmexMAX's Avatar
dot dot dot ...
Hasn't been posted if it has been tried...
Old Oct 27, 2005 | 04:12 PM
ICULookN's Avatar
Not bad#'s.
Old Oct 27, 2005 | 04:26 PM
GBAUER's Avatar
How about the other numbers: $? What are they running price-wise. It's either headers, cams, full exhaust, and an engine bore this winter or rebuild + custom turbo on the 3.5 with all the goodies to make it work right. Either way, I'm looking at around 10k in the engine. Hopefully it'll move well then...
Old Oct 27, 2005 | 04:28 PM
99 SE-L
With Automatic transmission it will start slipping at first shift
Old Oct 27, 2005 | 04:34 PM
GBAUER's Avatar
I kinda left out a little somethin' somethin' that'll also be done...
Old Oct 27, 2005 | 04:55 PM
MaximaPolak's Avatar
So how much hp and tq did the headers add?
What was your HP before the headers?
Old Oct 27, 2005 | 05:09 PM
rbrown81's Avatar
I did not get a baseline dyno run, but we can assume my car was running the same numbers as most maximas. 205whp and 215 tq
steven88's Avatar
Need A Light?
he does not have a baseline dyno...so we will never know
but my bet would be a 205whp baselin....so we are looking at around 30whp+ increase with his mods...
Old Oct 27, 2005 | 05:13 PM
rbrown81's Avatar
Old Oct 27, 2005 | 05:15 PM
Stalldaworld's Avatar
+1 for 30+ hp gain
Old Oct 27, 2005 | 05:28 PM
NmexMAX's Avatar
dot dot dot ...
VB mod fixes that .. ...
