Spoiler loose - argh
Old Nov 6, 2005 | 06:54 PM
DukeN's Avatar
My 2000 GLE has a loose spoiler, again.
First the right side bolt was missing, so I had it screwed in at a bodyshop (was at an angle, couldn't reach it myself).
Now, the left side is loose, but the problem now is that there is nothing to screw onto! The friggin nut/stud/whatever fell into the trunk cover assembly.
This happened within a 1 week period - any known issues/recalls I should be aware of?
Also, any possible DIY fixes are welcome, because I get the feeling the dealership will just molest on this one.
Old Nov 6, 2005 | 09:55 PM
foodmanry's Avatar
Da Roller Coaster!
No known TSB or recalls for this one, but you may want to think of removing the entire spoiler yourself. Not only is it held on by bolts, but double-sided tape so it can be a bear to remove. But with that it should give you access to rethread the stud.
Maybe someone else has a better idea.
If you aren't that mechanically inclined then I'd just take it to a a body shop to have them do it. They would be cheaper than a dealer.
Old Nov 6, 2005 | 09:59 PM
TPenguin's Avatar
Got Penguin?
Looking at mine, I would take the other stud to a hardware store and replace it with the same tread depth and do it that way but i would also use Loc-Tite to secure it down... You should be able to find something that will fit without any problems.
Old Nov 6, 2005 | 10:54 PM
scopium
take off the spoiler.. double sided tape and screw will do the job
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
