Whistle with Berk intake on '01
Hey, recently installed a Berk Intake w/Apexi filter on my AE '01. Now there is a pronounced whistle when I press the throttle with a certain force. With light pressure, it's a hissing, then with moderate, a loud whistle, with full throttle, it goes away. I checked all the connections and bolts. Everything is tight as you could want. The largest vacuum hose seemed a little loose, and there are some other lines (from the original stock intake) wrapped in this plastic "accordian"-like material that has cracked. Could that be the source of problems? Could it be the filter itself maybe cracked?
-Rich
The largest hose will fit all the way, but even with the clamp on I can still pull it off without a lot of effort. Do I need to get a new, tighter clamp?
the whistle is the air flowing over the throttle body butterfly valve at certain degrees of open-ness. It's there with the factory intake too, but you can't hear it because of the baffled/chambered setup, which muffles it to basically nothing.
maxima297
09-30-2015 03:32 PM
