Tire - Center Wear. Have you seen this? What pressure do you run?
Old Nov 21, 2005 | 06:43 PM
bert's Avatar
Well, just finished half of my tires and yet once again, they are heavily center worn. I would say 3-4mm low in the centercompared to the high point, measured visually using a straight edge. I have surely lost 1 season on each set.
This is the third set that I have gone through that have badly center worn. (2 summers (RE-92 'donut-of-death', Pilot Sport A/S, both stock size 225-50-17) and 1 winter (Blizzak WS-50 on steel rims 205-65-15).
The ususal suspect is high tire pressure. Checked that out. Ran the past year at 30psi. Didn't help.
I am starting to think that the base 32 PSI is too low and the tire is overheating and therefore is picking up too much pressure. Running 30 only worsened the problem.
Questions to all:
- Have you experienced center wear?
- If so have you solved it?
- If so how?
- If you have not experienced center wear what pressure do you run.
TIA,
Old Nov 21, 2005 | 07:35 PM
DonGfun's Avatar
VW = 30 MPG
I had center wear on Pilot Sport A/S but was running 40 to 50 lb. Got over 45K miles off them. IMO I think 44lb is max. so 37 to 40 would be good.
Old Nov 21, 2005 | 08:15 PM
irish44j's Avatar
retired moderator
From my and my neighbor's experiences, the Pilot sports seem to be notorious for center wear. I and he (on his 4th gen) had the same problems...mine wore allthe way to the cord and the sides were fine...running factory pressures. No idea why...
Old Nov 21, 2005 | 08:22 PM
AnDyMaN's Avatar
im on 245 45 18 and i always have outer wear..... but im upping my pressure from like 35 to almost 40...... my sides are worn out more than the center, so im trying to balance it back out...... but i would also be interested in what other people put their tire pressure on......
Old Nov 21, 2005 | 08:53 PM
ghostrider17's Avatar
235/45/17 Kumho ECSTA's, 25k miles, @35psi - seem to be wearing fairly evenly.
These have only 1-2k miles left b4 they're toast.
i won't be getting these again, need something a little more commuter friendly. But decent tires for the buck.
gr
Old Nov 21, 2005 | 09:25 PM
BigFly_2K2SE's Avatar
I have center wear on my stock 225/50-17 Potenza death donuts. However I typically run pressures close to 40psi so I attributed the wear to this. I have since backed the pressure off to close to recommended pressures and will see in awhile what the effects are.
Old Nov 21, 2005 | 09:33 PM
PandaXpress's Avatar
i run 35 in the winter..because there isnt as much heat...so the pressure varies between 34-38...in the summer i might drop to about 33 psi because the heat will expand the air in the tire, causing variations between 35-39 psi....thats just how i roll...
P.S. If you are lowered i believe that you need a bit more tire pressure...but i need to double check that.
Old Nov 21, 2005 | 09:36 PM
upstatemax's Avatar
235/45/17 Conti Extreme contacts, I run the fronts at 36psi and the rears at 34psi. All four are wearing perfectly even... even while slammed on D2's.
Old Nov 21, 2005 | 11:09 PM
2001SE's Avatar
I used to to put 33psi front and 31psi on rear. Not good handling and not good MPG.
I bumped it to 38psi front and 36psi rears, and it was much better just harsher.
I think I'll change it like upstatemax said. 36psi front and 34psi rear on both the maximas
Old Nov 22, 2005 | 07:29 AM
boondoxmax's Avatar
I like my nitto 455 at a pressure of 35-37 psi. At 32 the handling sucks and the ride is to soft. Wearing perfect though
Old Nov 22, 2005 | 07:51 AM
† ErV †
I get edge wear no matter what and have to overinflate (if the stock 33psi can even be considered inflation) to get the center to wear... my camber is in spec.. odd.
Old Nov 22, 2005 | 09:23 AM
Bluesbrekr's Avatar
Doctorate in Detailing
I have center wear on my Falken 512's on the front. Running 33 lbs. lowered about 3" with D2's. I just noticed it when I changed to my winter tires.
Old Nov 22, 2005 | 09:27 AM
SoonerFan's Avatar
Cletus
i had those tires on my 00 and had center wear no matter what pressure i was running. crap tires IMO
Old Nov 22, 2005 | 10:07 AM
Skier's Avatar
Believe it or not... running low pressure can in fact cause center wear as well as over inflation. Depending on the materials used in the tire, some actually centrifically spin the center of the tire out to the point where the center runs higher than the edges (especially if your a 80+ MPH highway runner). I ran 28-30lbs and saw center wear. I now run 35 front/34 rear and consistantly get even wear... Good luck
Old Nov 22, 2005 | 07:52 PM
BewstAdd1ct's Avatar
this is true, and especially in wider tires and lower profile tires.
Old Nov 22, 2005 | 09:25 PM
CCS2k1Max's Avatar
Never had any wear problems since new. Ran 57-58K miles on the RE92s at 35 psi and still had 4/32" left all around. I then wasted my time with Falken 512s for 3300 miles and wore the outer edges off faster than the rest of the tread, but that doesn't count; the 512s suck caulk. After that I ran Dunlop Winter Sport M3s last winter for about 6K miles at 36 psi and had no problem (11/32s all around). Until this past weekend I ran Fuzion ZRis at 39 psi for about 10K miles and had no problem (8-9/32s left I think. I actually didn't check before I put them away. Last I checked when I rotated them mid summer, they had 9/32 all around).
vybz05
Dec 10, 2015 07:38 PM
Maxboy23
Sep 8, 2015 06:53 PM
02nissmax
Sep 5, 2015 01:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
