Installing silverstars in head/fogs.
Old Nov 23, 2005 | 03:23 PM
MAXclipse's Avatar
Im installing siverstars in the headlights and foglights and was wondering if anyone could point me in the right direction.
Old Nov 23, 2005 | 03:25 PM
TPenguin's Avatar
Got Penguin?
Umm what do you need help with, the Silverstars are plug and play... no modification is needed... Maybe I am missing with problem....
Old Nov 23, 2005 | 03:26 PM
02theMax's Avatar
I personally don't recomend them. I bought a set and they burnt out very quickly, go for something better if you can. This is my .02 though.
Old Nov 23, 2005 | 03:38 PM
MAXclipse's Avatar
I need instructions on how to replace them as in, do i need to take the rubber from around the headlight off? It doesn't seem to want to unscrew so I think I'm skipping a step. And for the fogs, I don't see where I would have access to change it out.
The silverstars will burn out quickly if there is any oil from your hands on the bulb. I had them in my 97 max and they lasted for a year.
Old Nov 23, 2005 | 06:58 PM
TPenguin's Avatar
Got Penguin?
Dude, pull on the rubber covering and it will come off, its simple... As for the fogs... You need to undo the plastic underbody panels to access the fogs. Unscrew the fog assemply and push it forward and it will come out... The fogs are a wee bit tricky but nothing too hard. The headlamps are well self explanitory.
Old Nov 23, 2005 | 07:07 PM
wesnine's Avatar
Makers Mark
When handling HID just handle with a towel as to not get contact with your fingers.
Old Nov 23, 2005 | 07:11 PM
Kevon1's Avatar
There great.
Have had silverstars in my headlights & fogs going on 18 months no problems. Just like the other poster said make sure your oily fingers never touch the bulbs. Use a lint free cloth to wipe the bulbs if needed. Do the same with the bulbs in your house like in a lamp & you will see a long lasting improvement
Old Nov 23, 2005 | 07:12 PM
MxdOut97's Avatar
do a search.
Old Nov 23, 2005 | 07:43 PM
merovi's Avatar
I got silverstars recently. I had a PIAA go out. when I put one in to compare you could tell that the PIAA was more of a whitish color(maybe a hint of blue but I wouldn't even say that). The light output seemed about the same. I am actually getting some MTEC's though to switch out. I dont like the silverstar. It still has a stockish color to me when compared to other bulbs that illuminate just as well. Could just be me. Anyways they are a decent bulb.
Old Nov 26, 2005 | 08:17 AM
Anarchist's Avatar
I messed with this the other day to try and re-aim my fogs. The writeup I used is below, but one of the screws was being a PITA to get out and as it was about 27º out at the time, I really didn't feel like messing with it anymore. So long as you can get the screws out, it should be a relatively painless process.
http://www.cardomain.com/ride/2076435/2
Old Nov 26, 2005 | 02:31 PM
hawnboy's Avatar
I wanted mt fogs to match my headlights so I originally replaced my fogs with Silverstars, but was unhappy with the look. I have since swithced to PIAA H3 Extreme Whites for a much closer match.
Old Nov 27, 2005 | 02:10 AM
getbigtony's Avatar
hey does anyone know if replacing ur headlights with EuroDezigns H4 8500, do u have to replace wiring harness or if it'll burn out or not. the ebay page claims u dont have to.
http://cgi.ebay.com/ebaymotors/BLUE-...QQcmdZViewItem
Old Nov 27, 2005 | 03:36 PM
Italiano's Avatar
SWIFT_Navigator
headlights are plug and play.. remove the rubber cover (maybe be a little greasy) and swap out bulbs.. the fogs you have to do a little more work, look at how to's for HID fogs on this forum and youll figure it out..
when i had stock headlights i had no problems with them and now i have high beam silver stars in my 2k2 lights.. dunno how they burn out on you guys
you have the stock 2000 headlights.. you cant get an HID kit unless you replace those.. unless you feel like melting them
Old Nov 27, 2005 | 07:56 PM
getbigtony's Avatar
thanks. figured it'll draw too much amp
Old Nov 28, 2005 | 04:29 AM
nicks79's Avatar
my stock bulbs are still lasting since January 2000. but i realize once I say that, they will burn.
Old Nov 28, 2005 | 07:57 AM
merovi's Avatar
you can get other bulbs. Just make sure they are stock wattage. Not garunteeing anything, but usually bulbs that are DOT approved mean they will not burn up your harness. otherwise, how would they get approved? but since they dont list the wattage of their bulbs, there is no way of telling without contacting them.
and italiano, the bulbs in the e-bay link are not HID bulbs, they are bulbs taht are made to "look" like HID bulbs. They are your regular old H4 bulbs.
Old Nov 28, 2005 | 07:28 PM
Charcoal95GXE's Avatar
With the amount of money i spent on Headlight bulbs and harnesses on my 4th gen..i could have bought a nice NICE set of plug and play hid's. Learn from my mistake and go buy yourself some. They look sexy and theyll save you a headache in the long run.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
