fog light problems...
Old Nov 28, 2005 | 08:18 PM
hawaiiankine's Avatar
I had a rock go through my passenger fog light so I ended up finding a replacement light on ebay. It was from an aftermarket company but was a lot cheaper than the ones from nissan. It fit great but I installed my new piaa's at the same time as changing out the fog light and now 2 days later, the lens is cracked. I am guessing it's from the heat. The stock fog light is fine though. Has anyone had this problem before?
Old Nov 29, 2005 | 06:34 AM
Mizike's Avatar
I had the same problem. Did your aftermarket foglight have "Depo" imprinted into the glass instead of "Nissan". I had Lamin-X on the foglight and it turned brown after a few days of use, then the foglight lens cracked. I also have PIAAs in them. My OEM foglight also with Lamin-X has not cracked or turned brown. I think the aftermarket foglight cant handle the heat from the PIAA bulbs light the OEM foglight.
Old Nov 29, 2005 | 07:05 AM
Skier's Avatar
Both of my OEM fog lenses cracked just days after installing PIAA"s...
This guy's opinion... Heat!
Old Nov 29, 2005 | 07:13 AM
bladerunr's Avatar
I had the same problem as Mizike.
Old Dec 6, 2005 | 07:26 PM
malakas34's Avatar
my guess is that the aftermarket one has a thiner lens and cant handle the heat or is made from glass instead of plexiglass. if you take a water glass and put hot coffee in it it will crack. i was looking for a fog light for my car because its cracked and found some for good prices. http://www.autobodypartsonline.com/c...10105423290.67
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
