IACV valve position
Old Nov 29, 2005 | 12:38 PM
super6's Avatar
IACV valve position
Guys, i have a dilema, I took my TB before to clean it up, with TB out I took the step motor apart from the IACV. after putting it back together, the RPMs were bouncing at 18-1900 but if I keep accelerating, it would go past it. Today i decided to take it apart again and I put in a new TPS, new MAF, (from friends car) and the same symptoms were there.
As i was looking at the little valve inside the IACV, i noticed it has two positions, flat and up. Here's my question: is there a difference how that little valve supposed to be before the motor goes in or it makes no difference?
Old Nov 29, 2005 | 03:30 PM
fred reid's Avatar
Quite likely you will have to check your trottle close adjustment.
Old Nov 29, 2005 | 03:43 PM
BewstAdd1ct's Avatar
no, likely you will have to perform idle air learn procedure.
there arent 'two' positions, its a continuously adjustable PWM valve.
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
