Trunk Issue
Trunk Issue
Hi Guys,
For some reason the trunk open warning light in my gauge cluster is on. I tried to open and close the trunk but for some reason the light remains on. I also noticed that the light in the trunk is not working. I took the bulb out and looks good. I also checked the fuses and none of them look broken. Does anyone know the exact fuse I should be looking at? Any other suggestions would be greatly appreciated.
Originally Posted by SC2K1
Bump. Anyone know how the trunk open light in the gauge is triggered? Also, which fuse would be repsonsible for trunk light?
But if that fuse were out, your keyfob would not be working either...
Kevin
Originally Posted by makdaddy386
If you look inside the spot where the latch goes into (car side, as oposed to trunk lid) there is a black square trigger which when depressed tells the car that the trunk is closed. You can see the light turn on and off when you depress it with your finger. I dont have my multimeter on me so I'm not sure if it is a positive or negative trigger but I would guess negative (completes circuit by grounding when triggered) if I had to, seeing as this is the most common. Also if you need me to take a picture of what I'm talkin about just let me know. I'll be more than happy to help.
Kevin
Kevin
Thanks for the info. I was able to locate the trigger on the trunk side. When I depress it the trunk light in the gauge cluster doesn't shut off and the light in the trunk is still out. Any other ideas?
You might want to check depressing the trigger I already told you about if you didn't already. I don't know that there is a trigger on the trunk side. There is a latch but my inspection revealed no trigger. I'm not saying that there isn't one on your car but I might have missed it on mine. Either way I know that the trigger on the car side is the one that tells the car what is going on. Try that...let me know.
Kevin,
I took a look again and the trigger looks good. I'm able to depress it and it looks to be mechanically working. Any other suggestions? Thanks
1. Check bulb
2. Check voltage in bulb harness
a. if no voltage or partial voltage check related fuses
b. Check continuity in lines for wires grounding out at all
3. Visually see if depressing trigger changes anything (light come on?)
a. if no changes test to see if it is pos. or neg. trigger
b. test to see that wires recieve signal from depressing trigger
4. Pull out gauge cluster and test wires for what is recieving power.
a. trace these lines back to fuse panel, relay box, BCM, etc.
b. find lines that feed into the box (wires on the trigger side) and test to see that those are recieving power all the time
5. If everything checks out...find hammer and repeatedly beat cluster before replacing in dash.
Or you can disconnect your status light.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
BrandonCause
Sep 14, 2015 10:41 PM
rbaker100
Sep 6, 2015 02:46 PM
