chattering noise when accelerating, timing chain??
Old Dec 1, 2005 | 11:24 AM
dlee27's Avatar
Hi,
I have 2000 SE and I'm getting chattering noise when I'm accelerating between 1000-2000rpm. It's weired that it only happens when engine is warm. It goes away if I release the gas pedal. I'm sure it's not pininging sound.
Could this be timing chain problem? I saw the VTC sprocket TSB on 5.5 gen but I don't think that's the problem. Any thought?
Thanks.
Old Dec 1, 2005 | 11:55 AM
igzy's Avatar
I Know Kwaliti
I would open the hood, and with your hand move the throttle body cable to get the revs up and listen to where the noise is coming from... It could be as simple as a bearing on the alternator or drive belt...
Old Dec 1, 2005 | 12:02 PM
dlee27's Avatar
I forgot to mention this. It only happens when car is moving. If I press gas when car is sitting I don't hear it.
I first thought it's heat shield rattling but I'm not sure.
Thanks.
Old Dec 1, 2005 | 12:27 PM
NJDevil210's Avatar
i have the same thing in my 03...i wish i knew what it was....if anyone here knows help us out...
thanks
Old Dec 1, 2005 | 02:02 PM
maximaownsyou's Avatar
same thing in my 02... kinda seems like exhaust rattle? it seems like im hearing it towards the rear portion of the car but not sure any help would be great
Old Dec 1, 2005 | 02:16 PM
p51mustang's Avatar
If the noise is in the rear on the passengers side then it's probably the heat shield rubbing against the exhaust pipe. I had that problem and just bent the shield towards the back of the car about .5 inches.
Old Dec 1, 2005 | 02:17 PM
ok thanks will try that
Old Dec 3, 2005 | 04:18 PM
NJDevil210's Avatar
any other ideas? i was thinking it might be some kind of exhaust leak...i cant seem to pinpoint the noise on my 5.5
doug
Hondarydr
Dec 30, 2024 06:15 PM
boomerbrian
Nov 8, 2015 05:10 PM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Gsantos79
Aug 8, 2015 07:41 AM
