Morning lag ..
Old Dec 3, 2005 | 10:49 AM
BigL0U's Avatar
Morning lag ..
after hours of lettin the car sit.... if i dont let it warm up and drive off right away the engine would be hesitant and then eventually run just fine. Even when on idle later that day it may stutter sometimes too. Within the last month it has turned off on me. Am i gonna have to ALWAYS let it warm up before i head out? im in miami so the temp cant be that bad. i was told that it might be the oil thats too thick since my last oil change. what the hell could it be?
Old Dec 3, 2005 | 11:14 AM
paralyse's Avatar
I Miss My Maxima
Mass Airflow Meter (MAF) is your most likely suspect.
Old Dec 3, 2005 | 12:41 PM
brad1384's Avatar
Same problem
I replaced 2 MAF and still have stumbling.
Old Dec 3, 2005 | 08:21 PM
ColdSHO's Avatar
3rd maf still have this problem.
Old Dec 4, 2005 | 08:01 AM
nismo_star's Avatar
Then you guys need to clean TBs 1st and if that don't do it, go to the dealership and get your updated programs for the 'updated' MAF that is in your vehicle, I hope you have your receipt from when you purchased your MAF
Old Dec 4, 2005 | 10:19 AM
BigL0U's Avatar
Newb here .. how much "should" gettin the throttle body cleaned cost? can most shops do such procedure?
Old Dec 4, 2005 | 10:41 AM
nismo_star's Avatar
should be enough threads on it on this forum, check the stickies, sorry I cant be more specific, but a competent shop or a fellow .org member should be able to help ya out.
Old Dec 4, 2005 | 01:40 PM
Gray305Max's Avatar
Opa-Locka Goon
If you need help cleaning your TB, i'll help im local.
Old Dec 4, 2005 | 05:32 PM
cpuguy06's Avatar
Do the 2002s have the same problem as the 2000 and 2001 with the bad MAFs?
Old Dec 7, 2005 | 06:30 PM
BigL0U's Avatar
I shouldnt have to worry about the MAF Sensor do i? just the MAF Meter?? Besisdes gettin the throttle body cleaned....
Old Dec 7, 2005 | 07:51 PM
Champ2433's Avatar
If you have already upgraded your MAF to the newer update, green dot, you will need to have your ECU reprogrammed in order to get rid of the hesitation in cold weather; cold operating temperatures.
Old Dec 7, 2005 | 08:03 PM
BigL0U's Avatar
im in miami ..no cold temp here. still have the stock MAF *BUT* do i need to change the MAF Sensor or MAF Meter for Rough Idle and Stumbling after cold start ??
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
gigabyte
Jan 6, 2017 06:05 PM
mpbclutch33
Dec 26, 2015 11:11 AM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
