Annoying steering-wheel vibration @ highway speeds. :nupe500:
Old Dec 4, 2005 | 08:17 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Alright, here's the deal...whenever I'm driving on the highway, the wheel vibrates...nothing terrible, but annoying enough. The question is, is my suspension in need of some work...or is it my tires?
Thanks for the input, fellas.
Old Dec 4, 2005 | 08:20 AM
nismo_star's Avatar
What kinda wheels, tires ?
OEM or Aftermarket, if so got hubcentric rings ?
Start with that and go from there.
Old Dec 4, 2005 | 08:50 AM
zoner's Avatar
Could be quite a few things to the best of my knowledge..
Does the vibration get worse when you hit the brakes at speed? If so, I'd say brake rotors...
Could be a tire that needs balancing, a flat spot on a tire, I've even had steering wheel vibration from a bad rear wheel bearing - though of course I heard the bearing noise at the time.
Good luck
Old Dec 4, 2005 | 08:51 AM
PoLo's Avatar
2-Wheelin it...
sounds like a balance issue to me. either wheels are unbalanced due to lack of weights or you bent a wheel, at which point a weight wont' do much.
Old Dec 4, 2005 | 09:02 AM
OEM 17" SE Wheels on Pilot Sport A/S Tires...no hubcentrics.
The rotors are shot already, there is no doubt in my mind about that. I'll be replacing them after X-Mas.
Sounds like it's a balancing issue. I've never hit anything with the wheel, and cannot see any visible damage on any of them.
Any place you'd guys recommend for wheel/tire balancing?
Old Dec 4, 2005 | 09:05 AM
PoLo's Avatar
2-Wheelin it...
if tires are wearing out unevenly, that will also cause a balancing issue.
you're in jersey, so i dont' know...i have a local shop that for the most part, the guy knows what he's talking about. i think if you go to any shop but keep an eye when they balance, you can see as well what's the issue.
Old Dec 4, 2005 | 09:16 AM
PoLo's Avatar
2-Wheelin it...
adding another choice:
when i first got my 2k2, on the first day it snowed, the snow had iced into my wheels. when i was driving it causing some CRAZY vibrations. i couldn't figure it out until someone else mentioned it and it got coincedental. i kicked off the snow and all was well again. def. caught me off guard as it appeared outta nowhere.
Old Dec 4, 2005 | 09:55 AM
NYPD-Arnold's Avatar
Z
I had the SAME thing happen to me early this year. I was driving to school after second big snow storm and I bugged out! My car began to wobble violently after 50MPH. The thing is, I cleaned out the snow/ice on the wheel, but there was more behind it. I turned the car around and ran to Hogan (at Star Nissan) and I thought my car went bonkers. And he's like "dude...you probably just have more ice stuck there" -- he crouched down and whiped it down. Needless to say, I felt like an *** AND I missed my first day of class. Hahaha.
Old Dec 4, 2005 | 10:00 AM
OHH NOES's Avatar
6spd Swapped
Another possibility I'm thinking about is wheel bearings...
Old Dec 4, 2005 | 10:52 AM
Kevlo911's Avatar
Kevlo for President
http://www.gsp9700.com/
Old Dec 4, 2005 | 12:40 PM
joebangaa's Avatar
i get this too...i was afraid one of my wheels are bent but i'm not so sure about that... are there any common problems with stuff like linkages and such? possibly suspension wear? i hope it goes away after the coilovers go on...
Old Dec 4, 2005 | 01:23 PM
MoCoMax's Avatar
Depends on where in NJ. I use Euro-Tire in Fairfield - they do excellent work.
Old Dec 4, 2005 | 03:28 PM
Originally Posted by Kevlo911
Thanks, man. There are a number of places very close to me. I appreciate the help.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
mpbclutch33
Dec 26, 2015 11:11 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
