Automatic Transmission Flush (2002 3.5)... Do I have enough fluid in there?
Old Dec 14, 2005 | 01:57 PM
Colossus's Avatar
I flushed my 2k2 3.5L automatic transmission today using method in the How-Tos (drained 4qts from the pan, then drained 2qts at a time from the hose that was plugged into the radiator)
According to the owners manual, I can check the fluid in the cold range when I get the car to operating temperature, shift it through all the gears, and then check while idling. When I do this, I only see a hint of fluid on the edges of the stick.
When I let the car cool down and check the fluid when the car is off, the fluid is within the cold range.
Because no fluid is appearing when the engine is at temperature and idling, I'm pretty sure I need to add more fluid because it's not really showing up on the dip stick.... am I right?
Old Dec 14, 2005 | 03:24 PM
NewLoveI30's Avatar
Hard to tell... I can never determine how much ATF or oil is in my car. These dipsticks suk.
Are you fairly sure you put in as much as you took out?
Old Dec 14, 2005 | 03:57 PM
02theMax's Avatar
Yep, keep on adding and checking your fluid. Same thing happened to me when I did mine and I actually had to go back to the store to buy another liter of fluid. Just make sure you take your time and add slowly, drive a bit, add some more and repeat this step until your up to the full line. Good luck.
Old Dec 14, 2005 | 08:36 PM
GimmeTorq's Avatar
You need to check it while engine is idling either way (with the tranny cold or already at operating temp). Seems it is low. Like the other suggested, add the fluid slowly, like 1/4 of a quart at the time...
Old Dec 14, 2005 | 09:11 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
When I did my flush and the HOW To I used 10 Q to flush and If I recall correctly 8 remained in. Just check the stick when the car is cold to be safe.....
Old Dec 15, 2005 | 04:08 AM
maximaownsyou's Avatar
torque converter?
i heard from some of my buddies over in the tech shop at mercedes benz that the only way synthetic ATF will do any good is if you also drain the torque converter and replace that with synthetic ATF as well... is it possible to drain it? is this true?
Old Dec 15, 2005 | 04:11 AM
Lontar1's Avatar
Yes... follow mi Sig and you will know how.. NO need to drop the Pan.. by the way....
Old Dec 15, 2005 | 05:31 AM
sorry im not familiar with the forums *cough cough* <-- newb lol what do you mean follow mi Sig?
Old Dec 15, 2005 | 06:03 AM
UGAd13's Avatar
"sig" means Signature. The thing on the bottom of the post that people add to make them look cool, like mine. However, Lontar did not add his sig on the post right above yours. Follow this link,
http://www.cardomain.com/ride/335521/3
or click on AT Tranny Flush on his first post.
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
Maxboy23
Sep 4, 2015 06:04 PM
dcardello
Sep 3, 2015 11:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
