catalytic converters and Sirius
Hello,
I need to replace my bank 2 catalytic converter. Dealership wants $855.00 to replace this... It seems to me that an cutting the old cat out and replacing with an aftermarket cat is the more economical way to go. My question is this: Where can I buy an aftermarket cat that will pass CA smog testing?
Also, I want to install Sirius. Has anyone installed between the sunroof and windshield? It seems the back window would be better. What do you recommend?
Thanks in advance for your help.
-Chad
-Chad
I'm not sure what CA's emission testing is like. But, as I understand it the pre-cats (that's what you are talking about) really only have any impact while the main cat is warming up.
Presumably, if you take the car in when it is warmed up and have wiped the codes so the check engine light isn't on - you might skate. Unless, they are far more advanced than what we USED to have here in Florida.
Can't answer your question about the cats but I can about the Sirius. I am in the process of installing a Sirius in my car... driving around with no back seat or center console. I'm putting it between the rearview mirror and the roof. It's a tight fit but it will work. The antenna is on the trunk lid... with the wire running through the trim above the passenger side of the car. I'll have some pics soon.
Oh yeah... what kind did you get????
Oh, and as for the Sirius - I have the antenna sitting on the dash behind the clock. It is tied down with velcro along with the sunpass unit for tolls. Don't seem to have any reception problems.
As for putting the sirius unit itself between the rearview and the roof - it seems it will be harder to view and change channels there.
If you have it mounted in your line of sight with the road - it's much easier to pay attention. I just use the remote control - keep it next to the stick and just pick it up and change channels.
Originally Posted by SandSpit
Hello,
There is some discussion of that in this thread:
http://forums.maxima.org/showthread....hlight=pre-cat
DayHeyZeus
09-11-2015 03:17 PM
carid
09-09-2015 05:06 AM
