DIM SES Light
Old Dec 22, 2005 | 06:38 AM
compnurd2K2MAX's Avatar
DIM SES Light
At night my SES light has this very faint glow behind it.
When i start the car the light comes on bright as day as normal and during the day you dont see it, but at night there is this faint glow from it.
I took the car to autozone and the car spit no codes. i cleared the ECU anyway and the same issue.
Does anyone else have this problem?
The car runs fine.
Old Dec 22, 2005 | 12:00 PM
NismoGTR's Avatar
I had the same thing happen this weekend and posted it on Sunday.....Heres it is http://forums.maxima.org/showthread.php?t=445384......I got 1 responce.....And im not sure if its true what he said
Old Dec 22, 2005 | 03:38 PM
Bluesbrekr's Avatar
Doctorate in Detailing
It's a known problem. There have been many threads about it. I've had it since I got my 2k2. Replacing the cluster will fix it, but I've learned to live with mine. If there is an actual problem, the light will light up brightly.
Old Dec 22, 2005 | 04:21 PM
boondoxmax's Avatar
Yes it's a know problem. My 02 also had it and i had the cluster replaced under warranty. I wouldn't live with it if i was you. It annoyed the hell out of me at night seeing it glow a little. Nissan is well aware of the problem so take it to the dealer
Old Dec 22, 2005 | 05:11 PM
Bluesbrekr's Avatar
I had thought about taking it in to get the cluster replaced, but given the skill level of many Nissan techs, I was worried that the end result would be worse than living with the dim light.
Old Dec 22, 2005 | 06:16 PM
boondoxmax's Avatar
you will probably be fine cause only a certain tech can do it. When i took mine in i had to make an appointment cause they had to have a certain tech install it. The only thing they did which benifited me was when he set the odmeter back it wasn't correct. I took it in with 32,000 miles and when i picked it up. It had 31000 miles. Other then that i highly doubt the can screw it up.................
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
