Fog light bulb replacement? HELP!!!
God I've done and written this so many times. Many people have, it should be a sticky somewhere.
1. Get under the car and remove the screw on the side of the underside of the bumper and the 3-4 plastic tabs that keep the splash guard up against the car.
2. Pull the splash guard out of the way and get your head under the car so you can see the back of the foglight housing. There is a screw holding the housing in. Take it out.
3. Unplug the harness to the foglight assembly. With one hand on the outside of the housing pulling and the other on the inside pushing get the housing out.
4. With the housing out you'll have to remove the retaining clip and unplug the old bulb, replace with a new one and you're all set.
Reverse for installation.
GL
GL
GL
GL
Originally Posted by upstatemax
Last I checked the sticky is for an 02-03, and they have different fogs.
Fog Light Bulb Install (Russ2kSE)
Click on it and and you will see that it was posted in FEB 01....So this should work.
Originally Posted by NismoGTR
When u go to the HOW TO's this is what its under in the 1st post.
Write-up in his sig: http://forums.maxima.org/member.php?u=56038
Originally Posted by claudiusmaximas
i have a quick question to add: my foglight went out shortly after i removed my splashguard, does that have anything to do with my foglight shorting out?
vingodine
45
05-21-2016 12:46 PM
Viralkill
08-17-2015 10:54 AM
MikesChevelle
08-06-2015 11:36 AM
