can alcohol rub....
Old Jan 1, 2006 | 07:08 PM
The Law's Avatar
I R The Law
can alcohol rub....
can alcohol rub clean the rubber parts on the windshield wipers? cause i thought i remember reading something about alcohol rub cleaning the wipers but i cant seem to find the thread. any suggestion is appreciated
Old Jan 1, 2006 | 07:31 PM
maximaownsyou's Avatar
well i cleaned mine because they were sticking and hopping a little every time i used them, i just ran a rag over them with car soap when i washed my car, seemed to work
Old Jan 1, 2006 | 08:25 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
you can use alcohol on the rubber portion. most new wipers/blades come with an alcohol pad.
Old Jan 1, 2006 | 10:22 PM
steven88's Avatar
Need A Light?
Hey, are u tryin to clean your wipers cuz they streak? If so, just invest in some new blades....I bought some Michelin wipers at walmart for like $11 for both sides...they work great!
If it's for other reasons, then ignore my post
Old Jan 1, 2006 | 10:35 PM
The Law's Avatar
I R The Law
they kinda streak but not a lot, im asking this because they hop once ina while and i was getting stick of it hopping everytime i turn my windshield wipers on. also these are the stock wiper blades for all i know
Old Jan 1, 2006 | 10:49 PM
steven88's Avatar
Need A Light?
Oic...well u can always invest in new blades...its cheaper than I thought...I walked into walmart and saw they were only like $5 a pop...its not just refills either, its the whole assembly....I'm sure these will last for quite awhile...I mean Michelins do make one of the best tires out there....haha
Old Jan 2, 2006 | 10:48 AM
super6's Avatar
u can use rubbing alcahol to clean almost anything, its safe on paint and cleans virtually anything.
Old Jan 2, 2006 | 12:10 PM
NmexMAX's Avatar
dot dot dot ...
My last set came with a pad as well. Keeps the edge clean, and dry(at the moment in order to keep it minimal of dust and debris)
Old Jan 2, 2006 | 12:23 PM
kobalt's Avatar
I would be careful with rubber parts/mouldings as alcohol makes untreated rubber swell up
Old Jan 2, 2006 | 04:46 PM
steven88's Avatar
Need A Light?
so its safe to use on the body of our maximas?
Old Jan 2, 2006 | 05:48 PM
NmexMAX's Avatar
dot dot dot ...
It depends on you're using it on...
Old Jan 2, 2006 | 09:56 PM
Fezzik's Avatar
You can invest in some nice wiper blades like piaa. Mine have lasted for about 2 years without any problems. I've been up in canada a lot too in the snow and ice and no problems. Still cleans the windows like they were new.
Old Jan 2, 2006 | 11:31 PM
woosh's Avatar
Yes, 70 or 90% rubbing alcohol is safe to use on the body/paint. It's is actually perfect for cleaning bird poo.
Old Jan 3, 2006 | 10:56 AM
00MaxSE's Avatar
Pointy Elbows
I always thought that alcohol tends to dry out rubber and eventually crack it.
Old Jan 3, 2006 | 11:36 AM
igzy's Avatar
I Know Kwaliti
I had used Armorall (or whatever the spelling) to clean them and protect them from elements... It works well when sprayed on a cloth or paper towel and wiped a few times along the edge... Alcohol may dry them, but then again the windshield washer fluid is full of it...
chris j vurnis
Jul 22, 2003 11:45 AM
Uconn411
Apr 28, 2003 08:39 AM
TimW
Aug 2, 2002 08:09 PM
deezo
Jul 2, 2002 05:28 AM
SMX
Mar 6, 2001 08:36 PM
