THE YELLOW BULB vs LEXUS CAPSULE OFFICIAL COMPARISON...head-to-head!!
Old Jan 25, 2006 | 05:07 PM
  #121
merovi's Avatar
Originally Posted by 2kprlmax
Merovi - are you ruinning hid in your fog or regular bulbs. They look brighter then mine for some reason. I am on regular bulbs
Regular bulbs. The reason that it looks brighter is I cut the shroud. In order to get a really nice looking yellow light keeping the reflector tip is by cutting the surroundings on the shroud. I only left the 2 pieces at the bottom because they hold the reflector tip. If you look you can see. Normally, the shroud goes all the way around the bulb and even covers the top. This pic is with the top cut off. The next is with the way I have it.
Old Jan 25, 2006 | 05:34 PM
  #122
irish44j's Avatar
retired moderator
yep, that's the way to do it!
Old Jan 25, 2006 | 08:21 PM
  #123
merovi's Avatar
ya irish, like you said, if you were to re-open your housings, this works great. I feel as though I got about the same color as you(as I should) and I am keeping that stockish look with the reflector still in there. Not that it matters to you HID guys, but our stock headlights have the same reflector so it matches nicely.
Old Jan 27, 2006 | 06:58 PM
  #124
panchosmax00's Avatar
i really want to add that bright yellow to my fogs...i was lookin at the luminics but the capsules are lookin great...what do i need for these...hid fogs or can i use my oem fob bulbs and where do i purchase these yellow capsules..thanks
Old Jan 27, 2006 | 07:10 PM
  #125
merovi's Avatar
all of my pics and irish's pics are using OEM fog bulbs. NO HID. The yellow capsules can be purchased at www.hidtech.com
you have to e-mail them for info and make sure you get the 9006 capsule. they are $30 + $7 shipping. thats what it was for me.
Old Jan 27, 2006 | 08:07 PM
  #126
upstatemax's Avatar
And be very patient.... it can take a good long time for a reply.
Old Jan 27, 2006 | 09:31 PM
  #127
alright...im goin to attempt writing to hidtech...if someone can exactly help me out with the installation like a write up or somthin that be great..mayb merovi can help..thanks
Old Jan 28, 2006 | 11:24 AM
  #128
merovi's Avatar
1) Make sure you dissassemble your fogs so that there are no wires attached. Mine looked like this when going into the oven:
2) Bake fogs at 300 deg for 20 min. Don't under estimate this epoxy. Slowly pry with screwdriver. Caution it will be hot so use pot holders to hold the fog.
3) Let cool down for a few mins.
4) Unscrew the bulb shroud and cut it(i used a dremel) so that it looks like picture above in thread. Cut 2 of the tabs off the capsule and shorten 1. Line it up with the shroud so that it is clamping it between the shroud and the fog. Use Dr. Roy's pic from page 1 to further diagram this.
5) Try to get out as much of the old epoxy as possible. Use an exacto or something similar.
6) IMPORTANT!! Test the light. Put everything back together except the lens. Place the lens into place and plug back into the car with the foglight resting in place. Turn them on and make sure they are yellow enough and there is not to much light escaping behind the capsule. There will be a little bit but there is nothing you can do about it because it should not be sitting flush with the back. There should be room for air to vent.
7) Use a silicon sealant from your local auto parts store and line the fog light with it.
8) Put the plasitc(or glass) back into place and put screws in. I then ran 1 more line of silicon along the sides to make sure it was waterproof.
9) Let sit over night.
Thats the jist of it.
Old Jan 28, 2006 | 05:12 PM
  #129
upstatemax's Avatar
I am still waiting for an address to pick them up
I think I will get them quicker if I just paypal the damn money and have him mail them to me, eventhough he is most likely less than five miles away.
BTW I went to the address I was given earlier in the thread and it was someones house. I have no idea if he works out of the house or if he just mailed them from home, but I did not want to just walk up to someones house looking for shinny yellow things...
Old Jan 28, 2006 | 09:14 PM
  #130
2kprlmax's Avatar
merovi yes that is the way i have them. I did mine with Dr.Roy. Maybe my lights are dieing.
Old Jan 29, 2006 | 10:06 AM
  #131
VQuick's Avatar
Chassis Freak
Yeah, that's what I was afraid of, it sounded like a house address. You could try another of their e-mail addresses:
General Info: info@hidtech.com
Sales Inquiry: sales@hidtech.com
Retrofit Inquiry: retrofit@hidtech.com
Old Jan 29, 2006 | 10:10 AM
  #132
upstatemax's Avatar
I tried them both, I am just going to paypal the money and have them shipped.
Thanks for the address though.
Old Jan 31, 2006 | 04:20 PM
  #133
VQuick's Avatar
Chassis Freak
I bought some silicone adhesive that withstands temps to 400 degrees F, adheres to glass, and dries clear. Would it be OK to use this on the yellow capsule so I can fashion a reflector out of aluminum foil or is that a bad idea? The adhesive package says "may corrode some metals prone to attack by weak acids"...I don't know if aluminum foil would have a problem with that. Maybe I'll just forget about the reflector.
Also, I've JB welded the first capsule in place and it's lined up with an even distance around the bulb vertically but it's closer to one side of the bulb (horizontally) than the other. Is that asking for trouble? It's not close to touching but it's not centered. I wouldn't want my expensive, time-consuming yellow-fog mod to fade after a year or something.
Old Jan 31, 2006 | 04:25 PM
  #134
merovi's Avatar
If your talking about the capsule, no. The light will just shine through it. If the reflector is not centered, then the beam pattern will be really skewed and all over the place.
Old Jan 31, 2006 | 05:36 PM
  #135
VQuick's Avatar
Chassis Freak
Ah, good point about the beam pattern.
Old Jan 31, 2006 | 07:14 PM
  #136
merovi's Avatar
one of the main reason I redid mine after 1 day.
Old Feb 1, 2006 | 03:22 PM
  #137
Bluesbrekr's Avatar
Doctorate in Detailing
Luminics look very good to oncoming cars
Yesterday my son and I passed each other going opposite directions on a 4 lane undivided road. 45 speed limit. It was approaching dusk, about 4pm. He noticed the yellow fogs from quite a distance away and his first thought was 'Lexus'. Although he prefers white fogs on his SpecV, he said the yellow looked pretty cool.
Old Feb 1, 2006 | 06:04 PM
  #138
NewLoveI30's Avatar
Well that is the point now isn't it.
Though I still like the capsules better.
Old Feb 1, 2006 | 10:49 PM
  #139
2k2nismo.PL's Avatar
i would go with the lexus yellow it makes the car stand out more
Old Feb 3, 2006 | 02:46 PM
  #140
upstatemax's Avatar
Now it is friday and I still have not heard from HIDTECH and I dont have the capsules that I paid for on Monday. It takes ONE day to ship to me from where they are, that means that they have yet to even ship them (unless they shipped today).
I just sent another email to them that will most likely go unanswered.
Why do they have to be the only ones with this product???
Old Feb 3, 2006 | 05:48 PM
  #141
Teufelhunden's Avatar
i got the luminics too, but boy that lexus capsules are yellow. i wanna chagne mine, even though to my eyes the luminics are pretty yellow, i still want the capsules. ill do it when these burn out.
Old Feb 4, 2006 | 09:54 AM
  #142
igzy's Avatar
I Know Kwaliti
Don't worry about it for now. They will just show up in your mail box one day soon... Same story was with mine... If they do not come in a week or two, you can always place a complaint with PayPal and they will refund the money... IMO, don't worry, they are not the greatest in customer service and returning e-mails...
Old Feb 4, 2006 | 11:09 AM
  #143
VQuick's Avatar
Chassis Freak
Man, I must've caught them on a good day last month.
Old Feb 5, 2006 | 09:13 PM
  #144
VQuick's Avatar
Chassis Freak
Here's my progress. Unlike meanbean, I did not drill holes in the metal housing. Instead, I clipped off the three legs on the 9006 yellow capsule and just JB Welded it to the reflector. It's not quite perfectly centered on the bulb (stupid, I must have bumped it or something before it dried) so I'm going to try it without any bulb shield.
Old Feb 6, 2006 | 06:26 AM
  #145
Dr. Roy's Avatar
VQuick, before you seal those up you may want to stick a bulb in them and run it for a few hours. it will cure the jb weld and prevent the fumes from fogging your light
Old Feb 6, 2006 | 08:57 AM
  #146
merovi's Avatar
I hope you left some room for air to escape from the capsule. As irish points out, when heated the air expands and needs somewhere to go, otherwise shatter.
Old Feb 6, 2006 | 10:01 AM
  #147
meanbean's Avatar
upstatemax: I have purchased from them a few times and they have always sent my capsules so hopefully it will be any day now for you. I know this does not help you now but what I normally do is make a payment to them via paypal and include the notes for what style of capsule I need. I then send them a email with the subject "Lexus Yellow Capsules (PAYMENT SENT)." All my email replies have either been later that day or the following day. Within a week, the yellow capsules are on my door step.
VQuick: Nice to see you could get those lenses off without dremeling. I am glad to see that you have found an alternative method to mounting the capsules. I have recently done a visual inspection of my installation and I am happy to report that it is still holding up quite well after all this time. Hopefully, your installation will also have the same results. Good luck to you.
Old Feb 6, 2006 | 11:07 AM
  #148
upstatemax's Avatar
Well I guess I owe an apology to HIDTECH... they were here on Friday but my doorman was out sick and the F*ing superintendent in all of his infinite wisdom just took all the packages delivered and stuck them in a backroom Usually the doorman brings them up or hands them to you as you walk in.
So now I get to sit on them for three weeks till I go back upstate to install them when I was up there this weekend with tons of time to do it...
So, sorry to HIDTECH for blaming them right away when they were not in my hands, they did get them here on time.
PS- Yes, I will be sending them an email as well.
Old Feb 18, 2006 | 08:05 PM
  #149
upstatemax's Avatar
Well I finally got them installed and they look great.
Old Feb 18, 2006 | 09:37 PM
  #150
VQuick's Avatar
Chassis Freak
Look great, although they look like they're pointing more down than they should. Did you reinstall the inner reflector shroud or not?
BTW your avatar is hilarious!
Old Feb 19, 2006 | 08:05 AM
  #151
upstatemax's Avatar
I used Roys method and I cut off the top and sides of the reflector and reinstalled it. I do have to re-aim them, but it was 14 deg outside and I just wanted to get them in and get back inside.
Old Mar 20, 2006 | 02:18 PM
  #152
Puppetmaster's Avatar
Originally Posted by Puppetmaster
Some pictures of the RedlineMax Halos on their own with stock 4300k HIDs:
For prices and ordering information, please contact Corey (aka Redmax on the .Org) from Redlinemax.
http://redlinemax.com/catalog/
A month later and the Redlinemax yellow H3s are still burning bright.... neither has blown yet. I've left the fogs on for whenever my headlights are on (never used to do that). Just thought I'd let people know. Does anyone else around here even have these? I know Corey sold a bunch.
Old Mar 20, 2006 | 02:21 PM
  #153
steven88's Avatar
Need A Light?
My luminics are still going strong...anybody else have bad luck with them?
Old Mar 20, 2006 | 03:53 PM
  #154
igzy's Avatar
I Know Kwaliti
Here are my caps, no shield:
Old Mar 21, 2006 | 03:10 AM
  #155
Dr. Roy's Avatar
finaly got my oem foglight retro done, used a set of valeo H'7s w/ 3000k philips ultinons, not as yellow as the lexus caps but extremely bright
Old Mar 21, 2006 | 03:22 AM
  #156
Bluesbrekr's Avatar
No bad luck here...mine are still fine.
Old Mar 21, 2006 | 06:48 AM
  #157
2kprlmax's Avatar
I have seen these in person and they are brighter than my capsules, that we did. Looks good tho.
Old Mar 21, 2006 | 02:56 PM
  #158
JaKillz2's Avatar
hey igzy how do the caps look in the day without shields?
Old Mar 21, 2006 | 06:34 PM
  #159
igzy's Avatar
I Know Kwaliti
Here they are:
Old Mar 21, 2006 | 07:39 PM
  #160
JaKillz2's Avatar
but the actual capsule, like when the light is off, I was just wondering if it would stand out against the chrome or anything like that.
