THE YELLOW BULB vs LEXUS CAPSULE OFFICIAL COMPARISON...head-to-head!!
Old Oct 10, 2006 | 04:58 PM
  #201
irish44j's Avatar
retired moderator
Originally Posted by Rydicule
I just got the 9003 capsules in the mail yesterday, and after taking a look at them, they look a lot different than the capsules pictured earlier in this thread. They are not cylindrical like the ones in the pics, but actually look more like christmas tree bulbs, narrow at the ends and fat in the middle. I was going to attempt to install them today, but I'm a little nervous I may have gotten the wrong capsules
I will try to post pics since I haven't seen any yet with the 9003 capsules compared to the 9006.
that's what you get for not listening to us
just kidding...let us know how it turns out.
Old Oct 11, 2006 | 04:25 AM
  #202
Rydicule's Avatar
Don't you know who I am?
I did the install yesterday. I must say, I ran into some problems. First off, the capsule is too narrow at the bottom to fit around the raised portion to get the lip under the shield as shown in Dr. Roy's diagram. The opening on the capsule was actually JUST wide enough to get around the opening in the housing, so I had to remove the alluminum legs at the bottom of the capsule, and epoxy the plastic portion into the housing. I used five-minute epoxy, let it sit for about half an hour before putting the glass back on. I used that time to scrape the silicone off the glass (I used a potato peeler to do this, actually, it worked wonders).
After I made sure the capsules were secure enough (I could lift the entire housing off the table by the capsule), I went to put the glass back on. Behold, it didn't fit. My second "obstacle". The glass lens teetered on the capsule slightly, making it impossible to press it snug into place in the housing, one side of the lens would always stand slightly up. Can't really think of a fix for this, so I loaded the lip of the housing with extra clear silicone, pressed the lens back on, and then I put a whole @ss load of silicone on the side that stood slightly, and used a toothpick to smooth it over the side. Then I used another toothpick to scrape the remainder off the lens and housing where it had dribbled over, and I let it cure overnight, hopefully making an airtight bond.
The project has thus far looked great, exactly the look I expected, however it is only the day after, and I really can't tell if I completely sealed out moisture, as well as after running the fog lights on my way to work, I noticed a bit of an aroma coming from them. The capsule is touching right up against the glass, though I don't expect this to hurt much. I will say I suspect there is actually similar or even more space within the 9003 capsule than the 9006 due to it's shape and placement, but because of the epoxy, there really isn't any ventilation which could cause problems with continuous use of the fogs on long trips (fear of overheating and breaking).
Overall, things are good now. I would say if you have the cash and patience, stick with HIDtech 9006 capsules. The SUVlights 9003 will ABSOLUTELY NOT fit under the shield. No way, no how, if you use these it has to be removed. There could be problems with moisture as well, I know I put a whole crap load of silicone sealant in there, and there is no actual "gap" between the material, but it doesn't fit flush, so I'm a bit worried. If you are impulsive, impatient, and aren't going to if you end up ruining your fogs and have to replace them, then give it a shot and see what you can do with these. For the time being, I'm happy with them. We'll see what the months bring.
Old Oct 11, 2006 | 04:05 PM
  #203
Dr. Roy's Avatar
when i posted that link, suvlights had the same capsules as hidtech, not the ones below. they dont look like they would work well.
Old Oct 12, 2006 | 03:08 AM
  #204
Rydicule's Avatar
Yep. One of my fog bulbs just blew after only running the lights for the third time.
could be because I was running a higher watt silverstar that I had in before, could also be because when I had them out the ignorant and oblivious non-car oriented people in my house were touching them, or it could be just because the capsule s00k.
Either way, I'm
Old Oct 24, 2006 | 06:31 PM
  #205
02maxima35's Avatar
where do i get these yellow capsules
Old Oct 28, 2006 | 03:59 PM
  #206
VQuick's Avatar
Chassis Freak
OK, I FINALLY got around to finishing my foglight project. I installed the hidtech 9006 capsules in my OEM 4th gen fogs. Here is the result. If people bug me enough I will post a mini write-up, sans photos, for how to do this on a 4th gen. Meanbean's write up is very good, although I didn't cut up the housing like he did.
I installed 3M/Xpel 40mil headlight protecting film because after all this work, I did NOT want to deal with a rock punching a hole in my glass, or water splashing up and cracking the glass. The film is pretty easy to apply and it wasn't too expensive. I don't recall how much since I bought it about 2 years ago, LOL. It looks great and does not diminish the light output at all.
Here are some photos I just took. For comparison, the corner (clearance) light bulbs are orange and the headlights are PIAA Extreme White.
Old Oct 28, 2006 | 04:17 PM
  #207
irish44j's Avatar
retired moderator
looks great
Old Oct 29, 2006 | 07:59 AM
  #208
MyownNismo's Avatar
Future Camaro SS owner
I am currently working on these also but I am putting them in my 5 inch fogs. I have taken off the blue film and going to put then capsules in. But I asked for the h3 type capsules due to the shape of my lights. They sent me the 9006. I am working with them though and waiting for e-mail most likely tomorrow about getting the capsules I ordered.
Old Nov 4, 2006 | 06:55 PM
  #209
rmd0311's Avatar
Well., by the time I noticed this thread a few weeks back I had already purchased the Nokya 2500 h3's. Took me a while to get around to installing them. But I thought this thread would be a good one to show you guys... As soon as these burn out, going for the capsules. PICTURES ARE TERRIBLE... I suck at pictures.
Here are the pics Nokya 2500...
Old Nov 4, 2006 | 08:23 PM
  #210
Skylowmax's Avatar
Nice work irish44j....This should be sticky'd without a doubt
Old Nov 6, 2006 | 09:05 AM
  #211
JWoodstock0617's Avatar
HIDTech Not Responding
Does anybody have the phone number for HIDTech, it isn't on their website and they are not resonding to any of my emails.
Old Nov 6, 2006 | 07:30 PM
  #212
VQuick's Avatar
Chassis Freak
E-mail them again a few days later. It took me two tries to get them to respond.
Old Nov 6, 2006 | 07:53 PM
  #213
VQuick's Avatar
Chassis Freak
Here you go:
http://forums.maxima.org/showthread.php?t=499206
Old Nov 6, 2006 | 09:25 PM
  #214
GigEmAgs07's Avatar
can anyone post links to the two bulbs featured that weren't the lexus capsules? I searched the internet for an hour just now and couldn't turn them up.
Also, when i go to redlinemax.com, it sends me to vqpower.com, and there doesn't seem to be a boatload of products to buy there. I want yellow, but i'm not too crazy about doin the capsule mod. thanks guys.
Old Nov 7, 2006 | 05:23 AM
  #215
Rydicule's Avatar
I am actually currently running with these capsules. They do work, but you need to fabricate things a little. Easier to order than HIDtech, but I would stick with the 9006 if you have the patience. I did the mod on my bro's max with him with capsules I ordered from HID tech, and the mod went much smoother than mine did.
Old Nov 7, 2006 | 09:05 AM
  #216
XKlusive_Drunky's Avatar
I been wanting to do this mod but now i know for sure what i need to do and get.
This is a great thread definetly a sticky!!!!
Old Nov 20, 2006 | 02:22 PM
  #217
I had a lot of trouble getting in contact with HIDtech, but they did eventually email me. Thank you vquick for the thread about the person selling the yellow capsules. But, the email from HIDtech said this:
Hi Joe
Thanks for your inquiry. Each pair of Yellow capsule is $30 + $7 S&H. Our
paypal address is sales@hidtech.com Please note that this item is sold as it
with no return nor exchange, so please make sure you know how to work with
this before you purchase. May I ask what make, model your car is ?
Please also note that they don't just insert over your existing halogen
bulbs and then insert from behind the foglight. You will need to separate
your front clear housing first, then secure yellow capsule onto your
reflector housing by simply drilling three small holes and clip the tabs
from the bottom of the yellow capsule in, then seal the front clear cover
back. I would say this needs to be done professionally, and we also provide
such retrofitting service. Our labor will be $120 (for Plastic foglight
front cover only. We don't do glass) including return shipping for your
foglights. Remember this is a one time investment, you can have yellow
foglight for as long as your own your car.
In addition, we have experienced that some foglights might create fog due to
excess heat trapped inside the yellow capsule. Again, your OEM halogen
housing is not designed to fit yellow capsule over, so this mod MIGHT
require you to down grade your 55 watt set up to H8 35 Watt set up. Actually
35 watt is pretty bright enough for the foglight. Anyways, please keep that
in mind for the worse case.
Please email us if you have any other questions.
Sean
HIDtech
so, if you know exactly which capsules you are going to buy, just go ahead and send the payment through paypal and he'll ship them right out to you.
Old Nov 25, 2006 | 02:58 PM
  #218
Johnbrooks302's Avatar
^^^SICK^^^
Old Nov 26, 2006 | 03:59 PM
  #219
Maxima9750's Avatar
I personally hate the fog lights on Lexus cars. I think they look weird having HIDs and yellow fog lights. It's like starring into the sun. But that is just me.
Old Nov 30, 2006 | 11:11 PM
  #220
Triple8Sol's Avatar
I miss the .org!
IRISH: You're famous! This thread got linked by a thread over on G35Driver. Seeing my old posts brings back memories...haha. Running the Luminics JDM yellow now, and I love the color. Way more yellow than the PIAA's.
Here's some pics of my old car, with PIAA Crystal Ions:
Old Feb 1, 2007 | 10:47 AM
  #221
KCMAXX's Avatar
KC's FINEST
Does anyone have a contact # for HIDtech? Talk about slow customer service...
Old Feb 1, 2007 | 07:53 PM
  #222
maxspeed96CT's Avatar
The original VQ...
Does anyone else sell these thing, ive sent about 2 emails now to each address the give, ive been tryig to get these for over 1 month....
Old Feb 1, 2007 | 08:30 PM
  #223
VQuick's Avatar
Chassis Freak
Guys, just Paypal $37 to sales@hidtech.com and in the notes section put "9006 yellow capsules". They seem to be pretty bad at responding to e-mails (they ought to have instructions on their website, or a button to buy them right on the site) but if you send them the money they will probably mail them right out to you.
Old Feb 1, 2007 | 08:37 PM
  #224
irish44j's Avatar
retired moderator
I rule teh net!!!!!!
Yeah, I had to go over and comment in it, since I'm registered there.
Old Feb 15, 2007 | 08:07 PM
  #225
babyboyws6's Avatar
where can i get my hands on the HIDtechs and hwo much am i looking at here?
Old Feb 15, 2007 | 08:23 PM
  #226
VQuick's Avatar
Chassis Freak
did you read the thread at all? Look two posts above yours.
Old Feb 16, 2007 | 07:01 AM
  #227
Rydicule's Avatar
If you're brave, you can check these out.
http://www.suvlights.com/product_inf...roducts_id=163
This product used to be the same thing HIDtech was selling, and at the time I ordered from suvlights, they still had the 9006 capsules pictured. Then I got these in the mail. The install is not as "clean" as the 9006 capsules (at least on a 5.5 gen). The glass cover will not fit neatly back on, it teeters on top of the capsule. I just used a whole lot of extra clear silicone to compensate. I haven't run into any problems yet, and they look great. I thought I blew a bulb shortly after the install, but it turns out I just didn't secure the ground back very well . Easy fix though. Up to you
Old Feb 16, 2007 | 07:14 AM
  #228
OOmaxSE's Avatar
Everybody is looking for yellow capsules. Well, they are expensive ($38) and I guess HIDtech is hard to reach?
I think I may have an alternative. This will be my route once I swap bumpers.
Cut these and paste them inside the fog light housing (just as you would with the capsules). Will this really work by producing a true yellow for cheap ($10)?
IRISH, I'm not taking credit away but trying to create alternatives for the community.
Old Feb 16, 2007 | 09:06 AM
  #229
irish44j's Avatar
retired moderator
what do you mean by cut and paste them?
You can't "cut" a bulb - the glass is MUCH thinner than the glass in the HIDTech capsules and once the base is removed, it really has no rigidity at all and will just shatter after some minor bumps, IMO.
The HIDtechs may be $38 or whatever, but think about it this way: You get to use cheapo OEM-replacement bulbs ($3/each) instead of paying $20-25 each for PIAA H3s or Silverstars or whatever.....
Old Feb 16, 2007 | 09:34 AM
  #230
VQuick's Avatar
Chassis Freak
I agree that $38 is overpriced, but that's the way it is with specialty parts, they charge a lot because they can and they're often not produced on a large scale so it costs them more.
The economics of the yellow capsules isn't bad, though. As Irish said, once you install them you never have to worry about expensive bulbs burning out. And they cost about as much as a full tank of premium, big deal!
Old Feb 16, 2007 | 09:37 AM
  #231
OOmaxSE's Avatar
That was my shorthand term. I didn't want to spell it out but since you asked... You would "cut" the base of the bulb. Shatter may be an issue but if you're careful, I do'nt see how it's impossible. This is cheaper than the "colored" bulbs and you're still using the OEM H3. Maybe it just comes down to dishing out $10 and spending some time being creative, don't take it as a "comparison" or "competition", just more of an IDEA.
  #232
2k1maxgle's Avatar
Originally Posted by Johnbrooks302
^^^SICK^^^
I know this is a fog light thread and all....and yes I plan on doing this mod very soon as well. But I just have to ask...WHAT KIND OF HEADLIGHTS DO YOU HAVE IN THE PIC ABOVE??? Those are SICK!!! Can you let me know what kind, what bulbs, what whatever you are using? I know they are some form of angel eyes but damn...those are HOT!
Old Feb 16, 2007 | 09:40 AM
  #233
irish44j's Avatar
retired moderator
well do it already!!!!
Old Feb 16, 2007 | 09:41 AM
  #234
irish44j's Avatar
retired moderator
They're custom, with custom projectors. Dr.Roy is the master of custom headlights. You may want to get in touch with him to find out preciesely which setup of his that one is.
Old Feb 16, 2007 | 09:47 AM
  #235
OOmaxSE's Avatar
Didn't mean to "take" your thread in another direction. I posted this to give people more insight on "yellow" fogs. As you can see, people are strugging to get in full contact with HIDtech so this can be an option. I will try this but not until I get my hands on some 02 foglamps.
Old Feb 16, 2007 | 09:51 AM
  #236
irish44j's Avatar
retired moderator
I was serious - I love the ghetto mods....I actually want to see you do it and be successful at it. This thread is about yellow lights, so feel free to talk about any method you want to!
Old Feb 16, 2007 | 09:59 AM
  #237
VQuick's Avatar
Chassis Freak
Yeah, LOL, OOMax seems not to get it. Go for it man, we all would be happy if you got it to work. Irish doesn't care, you're not taking "credit" away from anybody. We may be skeptical but prove us wrong.
Old Feb 16, 2007 | 10:01 AM
  #238
2k1maxgle's Avatar
LOL....you guys are terrible....
Old Feb 16, 2007 | 10:03 AM
  #239
OOmaxSE's Avatar
^^^ ahah appreciate it guys! I'm ready to tackle it whether or not it's successful! Hold me up to it, springs coming around!
Old Feb 16, 2007 | 10:37 AM
  #240
Rydicule's Avatar
See my post right above this. Why would you take the time to cut and fit a yellow bulb when these concerns do exist? Wouldn't it be more worth it to order the capsules from the link I posted for 9 bucks? Given they are shaped differently than the HIDtech ones, they are cheaper and there is no messing around with emails and phone calls for em. I just think it would be a lot easier than cutting and fitting .
