Replace parking light lens in 02-03 headlight
Old Jan 10, 2006 | 12:27 PM
DUKEE's Avatar
I replaced my parking light bulbs about a month ago from. I believ ei got them from autolumination.com. A bunch of people recommended them to me then today i found out that they burnt right through my plastic lens on my 02-03 headlights. I have a 2001 max but i swapped headlights with the 02-03. So now i need to open these headlights up and replace the parking light lens. So my quesiton is where can i buy a replacement lens so that i can fix both my headlights? I am definetly going back to my polarg m4's in the parking lights!@!
Old Jan 10, 2006 | 03:28 PM
MIXXMAX's Avatar
Wow! Never heard of this happening before. The parking light bulb is only 5W max! It shouldn't get that hot to melt the lens. What was the wattage of your bulbs you put in? I have been running Polarg's in mine and never had a problem. To replace your lens, though, I would do the Malibu lens mod (like the clear turn signal lens mod), or maybe buy some wrecked up headlights (with no bulbs and ballasts) and use the lens from there. I'm just curious, though, what exactly kind of bulb did you use? I have bought bulbs from autoillumination before and never had a problem with their products and service. Do you have a link?
Old Jan 10, 2006 | 04:30 PM
DUKEE's Avatar
I bought these ones:
http://autolumination.com/images/auto_bulbs/194c_sv.jpg
I bought 2 of those and right now on the parking lens its like brown cause it burnt through it pretty much. Majorly sucks! Do you have a link to where to get the Malibu lens?
Old Jan 10, 2006 | 05:25 PM
MIXXMAX's Avatar
You can buy the Malibu lens from Home Depot. It's real cheap, less than $10.00. Just look in the outside lighting department and look for a package marked "Malibu". All it is, is a package of 2 round-shaped lights. You just want the lens cover from it. Bake your headlights in the oven for about 15 min. at 250 degrees and open them up. Pry apart lens from headlamp. Remove the parking light lens from the headlight. Trace lens over the Malibu one, cut with a Dremel and replace. Place headlights back in oven (until glue softens back up) and remove and tighten lens back on to headlamp. Your done!
Old Jan 10, 2006 | 08:43 PM
DUKEE's Avatar
wow. doesnt get any easier then that! thanks for the tip
Old Jan 10, 2006 | 09:46 PM
Nathan's Avatar
Only problem you'll have is finding these Malibu lenses in Canadian Home Depot stores. I've tried everywhere and was unable to find them up in Canada. It doesn't hurt to give it a try, but if not you'll have to get someone in the states to buy you a set.
Old Jan 11, 2006 | 06:00 AM
DUKEE's Avatar
ahh you're right nathan. i went to a home depot yesterday and i didnt find them. how much are they anyway?
Old Jan 11, 2006 | 06:09 AM
MacAlert's Avatar
They are around $8 US.
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
