Will these fit my car?
Old Jan 12, 2006 | 09:56 AM
maximo-SE's Avatar
Sorry if i posted in the wrong forum, but this thread gets accessed a lot more than the tire section. need feedback asap.
18x8 with a 20mm offset and a bolt pattern of 5x120
I need universal spacers ... ....???
im super rim noob. any help is appreciated.
Old Jan 12, 2006 | 10:01 AM
igzy's Avatar
I Know Kwaliti
Maximas run on 5x114.5 bolt pattern. As for offset, you would need an offset somewhere between 35-45mm though there have are members with rims outside these limits... The offset number indicates how far the rim lip is from the hub, the smaller the number the further away it is, so 20mm offset may be too far out of the wheel well... Overall, I don't think rims with those specs will fit a 5th gen Maxima...
Old Jan 12, 2006 | 10:08 AM
yofmatt's Avatar
what cars use 5x120?
*edit* nvm - As i recall 3 series use those
Old Jan 12, 2006 | 10:10 AM
yofmatt's Avatar
they should fit depending on what drop you have
Old Jan 12, 2006 | 10:11 AM
DrKlop's Avatar
Driving is the next best thing
no 5X120 will not fit maxima.
20mm offset might be ok if you not ganna get wider than 235mm tires.
Old Jan 12, 2006 | 10:12 AM
Ammi's Avatar
350 Detroit Muscle
wrong bolt pattern and offset is too low for the front.
Old Jan 12, 2006 | 10:13 AM
yofmatt's Avatar
I was saying for the size 18x8, igzy already said that pattern won't fit. so right back to you foo.
Old Jan 12, 2006 | 10:20 AM
LeX's Avatar
LeX
Nissan by Nature
I would think for a 2003 something along the lines of 38 or 35mm for the front and 30-35mm for the back would look pretty nice.
Old Jan 12, 2006 | 10:39 AM
maximo-SE's Avatar
thanks guys. saved me some $$$
Old Jan 12, 2006 | 01:16 PM
Ammi's Avatar
350 Detroit Muscle
why wouldn't 18x8 work? 18x8 works fine!
Old Jan 12, 2006 | 01:22 PM
yofmatt's Avatar
but I'd wanna go wider
Old Jan 12, 2006 | 03:16 PM
LeX's Avatar
LeX
Nissan by Nature
18x8.5 if you don't get too wide on the tires. Just ask Amit he had like 275+ on the rear
Old Jan 12, 2006 | 03:38 PM
Ammi's Avatar
350 Detroit Muscle
Or go staggered setup and mount 18x9.5 for rears or even 18x10
Old Jan 12, 2006 | 10:04 PM
designer485's Avatar
5x120 is a bmw offset!
Old Jan 12, 2006 | 10:11 PM
Hoooper
5X120 isnt an offset
Old Jan 13, 2006 | 05:55 AM
Ammi's Avatar
350 Detroit Muscle
try bolt pattern......
Lakersallday24
Jun 16, 2019 01:35 AM
stromm
Aug 27, 2015 04:13 PM
carguy96
29
Aug 21, 2015 02:43 PM
twotonezed
Aug 16, 2015 11:41 AM
kirkhilles
Aug 8, 2015 10:53 AM
