Brake Light Just Came On
Old Jan 15, 2006 | 06:29 AM
baltimax's Avatar
This morning while on my way to work I noticed that my brake light was still on. I checked the fluid, which was at the normal level. I changed a rear caliper in September but the brake light didn't come on. Nothing out of the ordinary happened today besides rubbing the curb while backing up. Any ideas as to where I should start?? It's cold and windy here so if there are any quick checks they would be appreciated.
Old Jan 15, 2006 | 08:24 AM
ressling's Avatar
HOOSIER Daddy?
maybe a short? check your wiring and check the taillight bulbs to see if a burnt bulb is creating a potential short... maybe also check fuse box.
Old Jan 15, 2006 | 09:06 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Originally Posted by jdmaxima89
Brake light fluid? Is that located next to the turn signal fluid??? Just kidding... good luck on your brake light! I have no clue.
Then why repply?? if you have no clue just stay away.
Check the brake fluid maybe you have a small leak.. add some more if that's the case...... the other thing could be brake pads going .......
Old Jan 15, 2006 | 11:45 AM
Mass_Media's Avatar
Mass_Media™
My light came on when i was low on brake fluid. It looked ok when i would look at it but when I would put on the brakes it would go down. Put some more in just to make sure.
Old Jan 15, 2006 | 12:08 PM
nupe500's Avatar
Jedi Knight
I was thinking fluid as others have mentioned. Also just double check that your ebrake is all the way down.
Old Jan 15, 2006 | 01:09 PM
sascuderi's Avatar
since it was raining and them got cold all of a sudden, maybe the emergency brake is not fully released because of icing?
Old Jan 15, 2006 | 06:00 PM
merovi's Avatar
that STP stuff works good but I prefere this stuff
http://kalecoauto.com/index.php?main...&products_id=6
best out there!
Old Jan 15, 2006 | 11:33 PM
Maximaum Driver's Avatar
Only thing I can think of is to check the charging system. Last time mine was goin out, all my dash lights came on (and the car died). So maybe this is a precurser to that. I'm really unsure.
Old Jan 15, 2006 | 11:53 PM
best out there!
Damn I need to get some of that stuff. Looks killer. I just had the shop replace my headlight fluid w/high quality Halogen fluid. They are damn bright now.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
