Installed Alutec FSTB...but problems
Old Jan 16, 2006 | 07:53 AM
n3985's Avatar
大陆弟弟
Today I went to install my Alutec FSTB, but encountered the intake manifold problem. I already put in 3 spacers per side, and the bar barely clears the IM, with about 1-2mm of space between. But, during startup, reverse, or stopped anywhere, I can hear knocking and/or feel vibrations through the car. I know another spacer can probably solve the problem but with 3 spacers already, the nut on the shock tower bolt is only down half way. Would it be a bad idea to add another spacer? Thanks
Old Jan 16, 2006 | 08:47 AM
MacAlert's Avatar
OT, but any pics of the bar installed?
Old Jan 16, 2006 | 08:51 AM
n3985's Avatar
大陆弟弟
http://forums.maxima.org/showthread.php?t=450133
and this is the pic of the bar and IM
The bar clears the left bump no problem, it's the right bump that is knocking.
Old Jan 16, 2006 | 10:19 AM
NisMoN00B's Avatar
+Cru OG
When you say "3 spacers per side" do you mean 3 spacers under each strut mount? That should be plenty (way too much I think) of 3/8" spacers to clear the IM.
Old Jan 16, 2006 | 10:28 AM
n3985's Avatar
大陆弟弟
3 under the strut bar bracket, and now I have 4 under each. I only have about 2mm of clearance and it STILL knocks once in a while!!! To top it off, since the Alutec bracket uses 2 strut bolts per side, the nuts on the bolts are barely on now due to 4 spacers, or about 1cm total of raise.
If you guys go to the Paradox site and look at the bar, the bracket part connecting to the bar itself is NOT raised like _l-------l_ as are the eBay and other cheaper bars. The Alutec is more like _/-------\_....I actually tried to dent the bar alittle to clear the IM bump, but damn...that bar is soooo strong.
Old Jan 16, 2006 | 10:35 AM
NisMoN00B's Avatar
+Cru OG
Looking at the bar on Paradox's site, *seems* like there's a little adjustment going up/down where the bracket meets the bar. Is the allen bolt's mounting surface a perfect circle on the bracket or is it a little eccentric/elliptical? Seems the little bugger is more of a headache than a quick install.
Old Jan 16, 2006 | 10:51 AM
n3985's Avatar
大陆弟弟
It is a little elliptical, to which I have already pushed the bar up as much as possible.
Old Jan 16, 2006 | 01:38 PM
spiromax's Avatar
Seoul Man
I've got the Megan Racing FSTB, and I had the same rubbing problem against the top of the IM when I installed my bar, but it wasn't quite as bad as yours. Mine would clear the IM by a couple of millimeters without any spacers, but it made a grinding noise in reverse when it came into contact with the IM. I used two washers on each bolt to solve the problem, and I even felt like that was a lot. You've already used 3 and now you're barly clearing the IM?
Old Jan 16, 2006 | 01:46 PM
NisMoN00B's Avatar
+Cru OG
Suggestion: Return Alutec FSTB and get a CE or Stillen. The Alutec does have a nice aesthetic appeal, but if it has to compromise safety...it's a no-brainer.
Old Jan 16, 2006 | 01:55 PM
Bluesbrekr's Avatar
Doctorate in Detailing
You could try grinding down the right side bump a bit for more clearance.
Old Jan 16, 2006 | 02:42 PM
MetaOrbit's Avatar
Got Projectors?
Ohhh I was afraid of that... I'm with some of the others. Return it or sell it to a VQ30 owner (they should have more clearance, shouldn't they?) and get a eBay bar or the like with more adjustability.
Old Jan 16, 2006 | 03:28 PM
n3985's Avatar
大陆弟弟
LOL ya right, I have as much chance returning the FSTB as I do with the clear sidemarkers Paradox sells, which the rear ones also don't fit. And of course it's never posted on the site the products *might* not fit.
As for the FSTB, I'm def keeping it as I can't stand the looks of any other FSTB available for your cars. I think I'll just grind down the IM a little bit, I'll update on how that goes.
Old Jan 17, 2006 | 01:50 PM
n3985's Avatar
大陆弟弟
So if I was to file/Dremel down the right hump of the IM, how much should I file off? Just enough to clear the FSTB? And how much is too much off? Thanks
Old Jan 17, 2006 | 03:03 PM
Larrio's Avatar
The Definitive AE Master
you bar looks upside down in the picture. But on your original thread it looks correct. The bar should be curved downwards on both ends going to the strut tower
I would recommend against only having a few threads onto the bolts, that is afterall the only thing holding your suspension in from the top
Old Jan 17, 2006 | 03:13 PM
n3985's Avatar
大陆弟弟
Haha, don't worry, it's on correctly. If I had it on upside down, the bar would balance around the IM bump.
Old Feb 6, 2006 | 03:08 PM
n3985's Avatar
大陆弟弟
Bump...
An idea occured to me today, what if I was to drill a hole in the bar where the right hump of the IM hits? I mean, the bar is rediculosuly strong as is, and I don't think a 1/2 hole will hurt structural rigidity that bad will it?
Old Feb 9, 2006 | 08:19 PM
n3985's Avatar
大陆弟弟
Bump...
Anyone?
Old Feb 9, 2006 | 09:06 PM
Mr. Blue Sky's Avatar
i think taking anything off of the bar will affect the way it works. How much I do not know.
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Tha'-Max
Aug 30, 2015 01:14 AM
kirkhilles
Aug 8, 2015 10:53 AM
